Originally posted by Voe Thanks Tim, a direct comparison would be greatly appreciated. I believe you are one of the few here who has both lenses.
Voe - I have just snapped a few shots at infinity - wide angle distant high-rises etc. It confirmed my impressions. The Zenitar at f/4 is virtually unusable. At f/5.6 it's getting there at the centre but not at the edges.
BUT - at f/8 I'm having difficulty seeing much difference at all at the centre between the Z and the DA15, and even at the edges things are not too bad with the Z. At f/11 it's even closer. I haven't defished the Z shots to check how much the corners deteriorate in the process - significantly, of course.
With a wide angle lens you can use very slow shutter speeds, so limiting yourself to f/8-11 is not as ridiculous as it sounds.
Hope that helps - although the answers were roughly what I expected,the Zenitar came out of the comparison rather better than I remembered, stopped right down. Wider than f/8, forget it.
Tim
