It's always worth carrying out tests with a TC to see if it actually works with your lens in the 1st place and also to find the lowest aperture that you can get acceptable results at. Also look at exposure it can also be different. In the case you quoted check that you are losing 1 stop. The 1.4x or 2x quoted by the manufacturer is a nominal figure probably referring to a 50mm lens at their unspecified test distance.
The Pentax AF 1.7x for instance on a 210mm lens is a 1.3x at 2m and a 2.7x at infinity!!! so a big variation in the light loss and for people who prefer it over a 2x (me included
) it comes as a big surprise to find that the Teleplus 2x MC7 has exactly the same magnification and light loss...... just different manufacturers, with different ways of specifying products
shim
