05-13-2010, 08:23 PM   #1
fearview's Avatar
Can We Put ND Filter on DA 10-17mm Lens?
since it doesnt have filter thread, i wonder if people want to use an ND Filter or Grad ND on them? is there anyway or trick that i dont know? i want some advice for this, i just borrowed this lens from a friend for a shooting trip, to where i might be need as wide lens as i can get .
the second question is there any substitution - cheap alternative for the lens cap? i am afraid im too careless and leaving that lens cap somewhere during the trip.. i am suspecting this metal lens cap must be pricey..
05-13-2010, 09:01 PM   #2
My 10-17 FE is the only lens that I have that doesn't have a B+W UV or clear filter. I think it's impossible.
I have thought about ordering an extra 10-17 FE lens cap , as I share with you that it would be very expensive to order the replacement, but with that big curved glass what else can one do.
05-13-2010, 09:06 PM   #3
Canada_Rockies's Avatar
QuoteOriginally posted by fearview Quote
Get a cap-keeper. You will have to be careful that it doesn't get in the field of view of that lens, but you won't lose it. You should be able to use a Cokin filter without the holder at the longer lens settings, but nothing can help you at 10mm. Honest. You will still have problems with the transition area. I suggest that the solution is not the ND filter, but rather to take two exposures, one for highlight and the other for shadow, and run it through post processing to map both. I have Photomatix, and Highlight/Shadow is about the only thing I use it for. HDR always looks too fake for me.
05-13-2010, 09:10 PM   #4
fearview's Avatar
canada rockies and lesmore
thank you. that would be explain everything.
i might need still bring my DA 16-45 with me i think.. for certain type shooting.
05-13-2010, 09:15 PM   #5
SpecialK's Avatar
No way would I use a dangling cap on a string, especially on the fisheye. It's hard enough keeping my elbows and feet out of the shot.
Put the cap in your pocket or bag - every time :-)
cap, da 10-17mm, filter, k-mount, lens, pentax lens, slr lens
DA 10-17mm Fisheye: filter possible blende8 Pentax SLR Lens Discussion 5 11-14-2011 12:00 PM
10-17mm filter size? timstone Pentax SLR Lens Discussion 5 04-06-2010 06:07 PM
Can I put a newer nikon lens on my K100d? Jewelz Troubleshooting and Beginner Help 9 10-28-2009 11:08 PM
What UV filter should i put on my DA* ? dreamnet Pentax SLR Lens Discussion 9 10-14-2009 03:42 AM
17mm Fish-eye filter question raymeedc Pentax SLR Lens Discussion 3 08-04-2009 11:04 AM
All times are GMT -7. The time now is 12:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
