05-14-2010, 08:29 PM   #1
Alex00's Avatar
77mm CPL on DA 15mm step up ring
Did anyone try to use a step down ring to make a 77mm CPL work on a 49mm lens. I have a B+W CPL that i want to use on my DA 15mm is possible. I'm not worried about CPL creating uneven skies. It will be used to remove reflections.
05-14-2010, 09:29 PM   #2
RawheaD's Avatar
You need to have an extra ring between the stet-up ring and the DA15's filter ring; the built-in hood interferes with the step-up ring.
I don't have a DA15 but my roommate does, and what he did was take a regular cheap UV filter, knock out the glass, and screwed that in between the DA15 and his stepup ring (77mm).
05-15-2010, 12:10 AM   #3
Alex00's Avatar
QuoteOriginally posted by RawheaD Quote
Wouldn't the 2 rings as you are suggesting still interfere with the the hood
05-15-2010, 08:21 PM   #4
RawheaD's Avatar
QuoteOriginally posted by Alex00 Quote
Nope.
77mm, 77mm cpl, cpl, da, k-mount, pentax lens, slr lens, step
step-up ring vs different size filters math guy Pentax SLR Lens Discussion 8 04-21-2010 09:43 PM
What 77mm hood for DA 16-45 + 67-77 + 77mm CPL zorobabel Pentax SLR Lens Discussion 3 06-30-2009 10:04 AM
Step up or Step down ring for FA 50mm f1.4 and filters. Xcom Pentax Camera and Field Accessories 4 05-11-2009 11:56 PM
All times are GMT -7. The time now is 05:45 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
