Originally posted by wlachan I know I will be bashed, but something has to be pointed out.
You will only be bashed for your inability to read what was clearly stated.
The thread referred to does contain 100% crops. Maybe you didn't get that far? They show even more clearly than the web-reduced images the superiority of the FA43.
Also try to realise that the demos are not meant to be an extensive tests, and in no way pretend to be. Rather they are "real world" demonstrative tests. In other words, I test by doing things the way I normally would, not by setting up special cases.
These limitations are clearly stated.
There are plenty of MTF tests that corroborate the info I have presented. Some of these are quoted verbatim.
Originally posted by wlachan Optically, FA31 is one of the best Pentax ever made
But not as good as the FA43 which is sharper everywhere except in the corners wide open. And rarely is that a problem in real use situations. (I would not recommend an FA43 for copy work but then again it doesn't have the magnification so the issue is moot.)
Originally posted by wlachan BTW, the Leica version was never popular or sold well. It was weak against the Leica lenses by all account.
That is not based on fact at all, but due to the mythic belief that Leica is just better. This is fully covered in
this post.
Please note that in none of this am I stating the FA43 is a perfect lens or the best ever in the world at any cost. I do believe it is the best Pentax has produced (or at least among the very best) and at its price is an absolute bargain.
