Originally posted by molko Just spent $1325.00 on a wide angle lens and I'm not impressed. What am I doing wrong!
I took a photo standing in the same spot with my normal lens and the wide angle lens. With the wide angle lens I got an extra window blind in. Not much difference at all. And when I do take photos I get an awful shadow at the bottom of most of my photos.
Anyone else find the same?
I find it the same on any lens that is longer and wider especially when used with the built-in flash. reason behind it, the size of the lens blocks off the portion of the light where it is supposed to illuminate. use an external flash or bounce flash inorder to avoid shadows or dark areas.
UW lenses are not meant for close up ultra-wide shots. I'm not saying it can't do close-ups but they are in general used for close corner wide shots like hallways. and landscape, cityscape, architecture shots that are taken with a bit of a distance. as you shoot the object farther away or with distance, the effect of the UW lens extra wideness is maximized. that's how this lens works and used for.
shooting window blinds at a fixed distance does not give the lens justice nor the proper use that it needs. work your distance.
