05-18-2010, 05:55 PM   #16
hinman's Avatar
If you happen to have a Tamron adaptall-2 p/k or p/k-a adapter, you can think about this
I like this 200mm quite a bit due to its small size, built-in lens hood and MF is charmingly good with my copy.
Thanks,
Hin
05-18-2010, 06:15 PM   #17
QuoteOriginally posted by kacansas03 Quote
I have a hole at 200 mm focal length in my lens setup but I am happy with what I have up to 135 mm. I would really like a sharp, good IQ lens that is somewhat fast, say quicker than f5.6 for around what is left in my lens buying budget of $60 to 70 total with shipping. Yes this may sound impossible but I am willing to adapt any mount to my K mount or a M42 mount or anything else in between. I ask for opinions for I am not that good at choosing lenses that have good IQ. I do wish to use this lens outdoors in limited light such as evenings or under heavy cloud which is why a little more aperture speed would be a good thing. I am thinking a prime focal lens as opposed to the 55-200 kit zoom. That lens seems too dark for my tastes. It's ok in bright sun but I don't always have that available. I await your suggestions and questions. Alan
I would go with the M200/4, for a few extra dollars if necessary, and be done with all the worry. Very reliable performer, lots of them around. Perfectly usable at f/4.
05-18-2010, 07:54 PM   #18
QuoteOriginally posted by hinman Quote
Thanks,
Hin
That is sweet. I do have both the PK and the PKA Adaptall 2 units along with the 140TC although I have yet to figure out the difference or how to take full advantage of the "A" lens. I am learning though.
05-18-2010, 11:25 PM   #19
Battling pheasants
I did not know that we had any pheasants in the area park but this evening I found 2 males really fighting it out. Never saw the female but she was probably around in the grass behind these guys.
PENTAX K100D  Photo
05-19-2010, 09:16 AM   #20
I think I might like to have a 200 f2.8 because low light performance could have been better. Either that or perhaps a 150 or 180 although I think they are more expensive even than a f2.8. I realize this is above the budget I first stated but now I feel I probably have the f4 to f5.6 are covered. It is that low light need that is bugging me. If I get a f2.8 that was intended for film I should be ok in all but night time or indoors and who uses a 200 mm indoors except maybe at a concert. I would bet there are a lot of opinions about 200 f2.8 lenses on this forum.
05-19-2010, 09:52 AM   #21
hinman's Avatar
QuoteOriginally posted by hinman:
I got my copy for about $100 and I think it is worth more than what I paid for. I saw copy of Tamron 200mm f/3.5 adaptall-2 04B going as high as $200+ without an adapter. It is not frequently seen in ebay but it does show up from time to time. I was perhaps wrong on the SP label. My copy has the model of 04B. More information can be seen in the adaptall-2 site
Tamron Adaptall-2 200mm F/3.5 Model 04B -- adaptall-2 site
If you have a adaptall-2 200mm that is f/3.5, you are likely have the same copy as mine. I took test shots in indoor setting in this flickr set
Church with Pentax K-x white and Tamron sp 200mm f/3.5 adaptall-2 (04B) - a set on Flickr
The best about that 200mm is the compact size.
Thanks,
Hin
When I use the 200mm with my K-x, I am quite happy with the performance.
05-19-2010, 09:58 AM   #22
hinman's Avatar
f/3.5 is plenty for me to work with K-x. Yes the grain can be a problem. If you can live with high iso 3200, you can save some dough.
1/100 sec, f/3.5, 200mm, iso 6400, 0 Ev
K-x white in jpg with Tamron 200mm f/3.5 adaptall-2 04B
1/100 sec, f/4.5, 200mm, iso 125, 0 Ev (with K20D)
Close up is difficult with minimum focusing distance at about 1.7m
color and contrast quite good in normal use, sharpness can be better
Some casual shot (with K20D)
Thanks,
Hin
05-21-2010, 06:58 PM   #23
200 4 for baseball
I am also looking for a SMC -M or -A 200 4 with a hood for junior baseball in the late afternoon.
I tried a zoom but no good toward the sun.
Last night I tried my -M 100 2.8 with a 2X rear converter and got excellent results. at 250th and equivalent f8 on 200 iso.
Next I am going to try a Takumar 135 2.5 with the rear converter, however the inbuilt hood does not give as much cover as the 100 2.8 .
Today I found a Makinon 200mm 4.5 and got it for $5 (!) plus shipping while I continue to look for an SMC.
The filter & hood for a 200mm is 52 mm so I hope I can get one with original hood.
The 100 2.8 uses a 49 mm hood. Incidentally, this hood is usable on all lenses down to 28mm on DSLR , but not on film format.
05-21-2010, 07:20 PM   #24
QuoteOriginally posted by wombat2go Quote
Quick tip. If you want a Pentax lens you are doing fine but there are several out there that are 200 f2.8. Tokina built them in their name(rare, very rare), Vivitar, and Soligor which is the "common" one. Do not get the f3.5 version. The good m42 version has a 77 mm filter and the good K or many other mounts has a 72 mm filter. Search for these names and you should be able to learn a lot. It was talked about on DPReview very positively but one must watch out for the usual in an older lens, dust de-lamination of coatings, haze, fungus and all. Do not go for the expensive eBay ones since you can get it for $80 to $150 for an excellent one.
05-21-2010, 09:17 PM   #25
mikeSF's Avatar
i don't have much to contribute here except that i bought both the M200/4 and the S-M-C Takumar 200/4 and spent some time doing side by side comparisons. the Tak was hands down a better lens than the M, IMO.
Now, i always keep that Tak200 in my bag to cover the long end.
it is a little outside of your budget but worth the extra money if you can swing it.
05-21-2010, 09:26 PM   #26
Eruditass's Avatar
Komine Vivitar 200/3.5's can be found really cheap and are quite good.
05-23-2010, 05:08 AM   #27
200 4 for baseball -done
Thanks very much for the advice of the above 3.
I now have the $5 Makinon 200 4.5 to go with the old Makinon Zoom I have.
That for general use and I expect it works OK on camera jpgs.
And for the Pentax collection I bought a K 200 4. It is bigger than the M 200 4 and a with 58 mm thread. Got for a little over the average price listed on this forum.
Old 200 2.8 were outside of my price range, better to buy a new one.
I looked closely at a surplus new ex kit DA 50 to 200. for about $160 - Fairly good reviews. But the kit one ( -L) has a plastic mount and .... waiting for full format anyway.
05-23-2010, 12:32 PM   #28
I will not see my 200 f2.8, which was under $100, until June so I can only comment on the lenses I own. The best is a Tamron Adaptall 200 f3.5. This is an older lens '76 to '79 model CT-200 but it has good IQ wide open in low light. I did not think it would be but it has really surprised me. It is a full 35 mm film frame lens which may add to the lower light images, I don't know. This lens was less than $50 but may have been half that cost. The hard part is the adapter which can cost more than the lens. I was lucky there in that I had adapters already and easily found more at a good price, just lucky I guess. I will post a low light pic from the Tamron as soon as I get one processed from RAW. The other off brand did not do well at all wide open and isn't worth mention so I will be getting rid of that one.
05-24-2010, 06:33 AM   #29
reeftool's Avatar
I bought a Tak 200/4 in the Marketplace a year ago for $45 so the good deals are out there, it just takes a little patience and the will to wait.
05-24-2010, 11:24 AM   #30
QuoteOriginally posted by reeftool Quote
Yes, they are out there! Now I am going to whine a little. What I really wanted was a 200 mm f1.8, Oh yeah that would be a low light wonder now! Anyway when my 200 f2.8 comes in from Canada in a week or 2 I will have to try it out and post some results even though I am not as good at photography as many on the board. I do not think people should assume that a digital camera assures perfect results, it still takes work and knowledge to make a good photo happen. So many on here and the whole forum have got the eye to do accomplish great things with their cameras. I'll just keep taking snapshots.
iq, k-mount, lens, mm, mount, pentax lens, slr lens
Any cheap 200mm fast cheap prime suggestions? tr13 Pentax SLR Lens Discussion 32 03-08-2013 02:30 AM
Seen on ebay : A bloody cheap 80-200mm f2.8 TAMRON thomas81 Photographic Technique 1 01-14-2009 05:35 AM
Cheap manual lens on cheap extension tube with cheap flash! Also cats. pasipasi Post Your Photos! 12 08-28-2008 04:43 PM
Cheap 200mm Zoom Comparison FotoPete Pentax SLR Lens Discussion 5 04-23-2007 02:21 AM
All times are GMT -7. The time now is 11:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
