05-19-2010, 06:03 PM - 1 Like   #1
pcarfan's Avatar
Pentax FA* 28-70mm/2.8 VS Tamron 28-75mm/2.8 at 50mm
Well, I just received the Tamron 28-75 and did some rough testing at 28mm, 50mm, 70mm at f2.8 f4 and f5.6.
Overall the FA* has much better rendering, sharper and the bokeh is never nervous, The Tamron is very good (even better than the FA* at 70mm at f2.8 wherer the FA* zoom is very very weak), but lags behind the FA* zoom slightly. The Tamron is less sharp, the bokeh at times can be a bit nervous but still very good. Overall pictures do look better with the FA*.
Here are a couple of sample shots at f2.8 and f4 at 50mm.
CLICK ON THE IMAGE FOR FULL RESOLUTION
Tamron 50mm f2.8 (Focus on the puppet's left eye)
Pentax 50mm f2.8
Tamron 50mm f4 (I took a shot of the glass, as fine lenses like the limiteds and the FA* render glass to look like real glass)
Pentax 50mm f4
05-19-2010, 06:26 PM - 1 Like   #2
Moderator Emeritus
I've also had both lenses and have the Tamron only now. For all intents and purposes, the Tamron is easily just as good. Like you mentioned, the bokeh is smoother with the Pentax. I also had the FA*80-200mm and Sigma 70-200 EX (older version -none macro) and the 2 are very much the same. I still have the Sigma.
The FA*'s are able to render better backgrounds but overall the IQ is very similar with the Tamron 28-75 and the Sigma 70-200. Certainly close enough that I think the FA*'s are over valued by more than double.
05-19-2010, 06:38 PM   #3
philbaum's Avatar
pcarfan,
I noticed in the second example that the clock face that you focused on (i assume) was sharper on the Pentax picture than the Tamron picture. However, if you look at the Stooges box in front of the clock, the Tamron picture is sharper than the Pentax picture.
Which i think means that this specific Tamron lens is front-focusing. If you have a K20 or K7, it would be interesting to throw a 3,4 or5 correction for the front focusing and then see how they do.
I have the Tamron which i purchased about 2 months ago and have been happy with the sharpness and rendering. I purchased it after reading the rave reviews in the database. By all accounts the Pentax is nice as well, but i don't have any personal experience with it to judge.
Best wishes for your selection,
05-19-2010, 06:46 PM   #4
pcarfan's Avatar
QuoteOriginally posted by philbaum Quote
pcarfan,
Phil, I saw that. However, if you check the dust on the top of the box on which the clock is placed it shows that the focus is only very slightly front focused. I used MF with LV anyways for my tests and at times AF and chose the best. But, I did notice the front focusing.
But, these tests are painful when it comes down to that single image posted. I based my conclusion from the 20-30 odd shots I took, not just these two. I just uploaded these for posting.
05-19-2010, 06:54 PM   #5
pcarfan's Avatar
QuoteOriginally posted by Peter Zack Quote
It is close in the testing, but the FA* is better in almost all aspects. is it worth the price difference ?, only time will tell.
Even the Pentax FA 77 takes a lot to fully exploit it's advantage. When I get it right, the FA 77 can do what no other lens can even dream of doing....only time will tell whether in general use the FA* can produce something stellar that a consumer lens may never can..... these minor differences already makes even the mundane shot look better overall, I think the FA* has some tricks up it's sleeve, as I see it in some of my tests.....I need to use it now and see.....
05-20-2010, 01:07 PM   #6
QuoteOriginally posted by pcarfan Quote
Thank you for posting this. I can see that Tamron 28-75 is a very good lens indeed but there is something that make Pentax 28-70 more pleasant to my eyes. Also it seems the photos from Pentax is a little bit brighter with the same setting.
Anyway, I'm more interested to your exploitation of FA77
Since I just got this lens and comparing it to DA70, what are the tricks that you've learned to optimize this lens? Thanks.
05-20-2010, 01:38 PM   #7
philbaum's Avatar
I can easily buy that reasoning, lens tests are very complex to do. Another thing that tests typically don't address is the long-term durability of the lenses. I wouldn't be surprised if the FA is out in front in that area as well.
Best of luck,
05-20-2010, 03:16 PM   #8
pcarfan's Avatar
QuoteOriginally posted by HermanLee Quote
HermanLee,
The Pentax is not brighter. The Tamron was consistently a bit brighter, and as brightness influence the appearance of the image, I PP to equalize the exposure based on the histogram. It is my error and the Tamron is the brighter lens.
I've had the 77 for almost 2 years but I don't have any tricks. When everything clicks the image is truly amazing, I wish I know how to consistently do it, it's hit and miss for me.
05-20-2010, 03:22 PM   #9
pcarfan's Avatar
Some more images that show the FA*'s edge.
Here is a brick image at an angle to avoid the FF/BF issue and a crop
Pentax (click on the image for full res.)
Tamron (click on the image for full res.)
100% crops (Pentax on the top)
05-20-2010, 03:27 PM   #10
pcarfan's Avatar
Overall rendition being better with the FA*
FA* (Click on the image for full res.)
Tamron
100% crops (Pentax on top)
P.S: DANG! THE PENTAX IS AT 31MM AND NOT 28...I ZOOMED AS WIDE AS POSSIBLE BUT THE POWER ZOOM DIDN'T GO ALL THE WAY...OH!WELL.
05-20-2010, 03:32 PM   #11
pcarfan's Avatar
70mm where FA* is at the weakest.
At f2.8 the FA* is useless, so did this at F4 where it almost catches up to the tamron, but still a little soft.
Pentax (Click on the image for full res.)
Tamron (Click on the umage for full res.)
100% crop (Pentax on the top)
05-20-2010, 04:08 PM   #12
pcarfan's Avatar
At 43mm where the FA* is much stronger
Tamron
05-27-2010, 11:45 AM   #13
Hello everyone, I wanted to know from you, if yours too, FA * 28-70, lose definition to 70 mm f/2.8.
I have noticed that by 60 you 70 mm, the lens loses much definition, I must close at f/4, to get good photos.
tkx
05-27-2010, 02:45 PM   #14
summonbaka's Avatar
Can you shoot some flowers or greens in an outside matter whenever possible? I want to see the FA* in this environment. It doesn't need to be a new photo, do you have one from before?
05-27-2010, 03:48 PM   #15
pcarfan's Avatar
QuoteOriginally posted by bollicina31 Quote
tkx
Absolutely.
It is unusable at f2.8 and 70mm, but by F4 it is fine.
50mm, f2.8, f4, fa*, glass, k-mount, pentax, pentax lens, slr lens, tamron
Tamron 28-75mm f2.8 or Sigma 24-70mm f2.8? bfo Pentax SLR Lens Discussion 15 05-01-2010 03:47 AM
help me make up my mind: Pentax FA 50mm f1.4 vs Tamron 28-75mm f2.8 macky112 Troubleshooting and Beginner Help 22 04-28-2010 09:17 PM
For Sale - Sold: Pentax DA50-200mm, FA50mm, M50mm f2, Sigma 24-70mm, Tamron 28-75mm ndy4eva Sold Items 9 09-04-2009 09:20 AM
Pentax FA 28-70mm f/4 vs Tamron 28-75mm f/2.8 bc_the_path Pentax SLR Lens Discussion 8 02-21-2008 01:36 PM
All times are GMT -7. The time now is 06:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
