Originally posted by Fookus Hi Jaitas (and others)
Would you please be so kind to help me out? I've got LR 3.3 but the DA 12-24 profile isn't included yet.
How do I load your calibrated DA 12 24 profile into LR3.3? I use Windows 7 and I don't recognize the path setting on my computer (as stated in this thread; I only see Program files/adobe or users/desktop/adobe; I don't see any folder with lens profiles).
thanks in advance
cheers Marcel
For Windows 7, you place the files in either:
Windows 7 or Vista: C:\Users\(User Name)\AppData\Roaming\Adobe\CameraRaw\LensProfiles\1.0
...replacing '(User Name') with that of the specific user you want to have access to the profile, or in:
C:\ProgramData\Adobe\CameraRaw\LensProfiles\1.0
...if you want all users to have access. I'd recommend the latter folder, to avoid problems.
Note that if you can't access those folders, you'll need to make sure you've set Explorer to let you see them. The default is to hide the ProgramData and AppData folders to keep you safe from accidentally breaking anything.
* Open an Explorer window, then hit Alt to make the menu with "File", "Edit", "View", "Tools", and "Help" appear.
* Click on "Tools", then "Folder Options"
* In the popup that appears, click on the "View" tab
* In the Advanced Settings section, find the radio buttons for Hidden Files and Folders, and make sure "Show hidden files, folders, and drives" is selected, *not* the "Don't show" option.
* Click "Apply", then "OK".
Once you've copied the files to the relevant location, you can undo the change above by going back to the same location, choosing the "Don't show" option, and then applying the change.
Also, make sure to restart Lightroom after copying the profiles to the right place, and make sure if the profiles are zipped, that you extract them to place the .lcp file (the profile file itself) in the right place, not the zip archive containing it.
