Originally posted by LadyRo ...I've read the lens reviews, searched these forums, and searched Google. It seemed that the consensus was that these were decent lenses, and sometimes excellent used in the right conditions. At the price I got them for, that's enough for me. I think I'll be better off shooting with these than sitting around not shooting while waiting for better lenses, that I can afford, to pop up on eBay or my local craigslist.
I think this is exactly the right approach. Yes, there are "better" lenses out there - there are
always better lenses out there. I bought them and they're nice. It doesn't mean the Takumar Bayonet is not capable of good work.
I did some testing of a few 135mm lenses here:
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/68032-135mm-le...imes-zoom.html
If you look at all the comparison photos, the differences are not that big. Most people would not see them, and processing could minimize the differences.
Quote: I read that as far as the 135mm lens goes, any of the M42 Takumar versions are supposed to be much better than the Takuamar Bayonet I have. But, I also read that using an adapter put space between the lens and the camera and that wasn't supposed to be good. Are the M42 Taks so much better that using one w/ an adapter would still be better than using the Takumar Bayonet?
The answer depends on which lens you're comparing it to. The adapter doesn't affect image quality at all for Pentax cameras, because there's no optical element in it. In fact the M42 lenses are designed to work at the exact same distance from the sensor/film as the K-mount.
There are only a few M42 (or other mount) lenses faster than f2.5. Prices on these put them in a different league. At f2.5, there's a Super-Takumar and two Super-Multi-Coated Takumars. The Super-Takumar is a little sharper in the corners at apertures wider than f5.6. The Super-Multi-Coated versions have better colors, more contrast and less flare. The later version has all that and improved sharpness. These lenses look almost the same and I think they look really cool on the camera. Your lens can focus a little closer than all of them.
The f3.5 135mm lenses vary a little more. Lens coatings make the same difference as above. The optical formulas vary more, and the different designs are better in different areas. I like the SMC Pentax-M 135mm f3.5 instead of the Takumar f3.5 versions, because it's a great size.
