05-24-2010, 07:29 AM   #1
How to disassemble the FA 28-70mm/F4 AL ?
There is some mold wire one the inner glasses. I want to disassemble the lens, and clean the glasses. Any one can tell me the steps to disassemble the lens ? With photo is better, Thanks a lot!
05-24-2010, 07:35 AM   #2
I strongly suggest against doing this yourself...if you absolutely need to, try to locate the parts manual online, if one has been uploaded for this lens.
05-24-2010, 07:48 AM   #3
some one has uploaded 2 pieces of disassembled lens, but they are not enough.
05-24-2010, 08:24 AM - 1 Like   #4
glasbak's Avatar
QuoteOriginally posted by nanaky Quote
Well, there are more pictures where that came from.
if the 'fungus' looks like this :
Don't bother, I could not remove it, it is probably between these two cemented (!) lenses
05-24-2010, 10:55 PM   #5
QuoteOriginally posted by glasbak Quote
Looks like the infamous element separation problem...
05-24-2010, 11:11 PM - 1 Like   #6
ovim's Avatar
I've got one which had a small amount of fungus. I was able to remove it by going in from the rear.
I had to first remove th light baffle with the square hole in it (I probably opened the screws around the bayonet but don't remember for sure). Then I removed the rear element with a lens spanner (well I used a caliper to screw open the ring holding the rear element). I don't remember if it was the inside of this element or the next one that had the fungus but anyway I didn't have to dismantle the lens much further to clean it.
05-25-2010, 08:58 AM   #7
thanks all above, some photoes to show me the setps will be more helpful?
glasses, k-mount, lens, pentax lens, slr lens
Disassemble the Pentax K10D maximm Pentax DSLR Discussion 8 10-23-2011 08:05 AM
What keys to disassemble?? Help pls bollicina31 Pentax SLR Lens Discussion 4 01-18-2010 12:33 PM
Need help to disassemble Pentax A 70-200mm lens manteiv Pentax SLR Lens Discussion 3 12-04-2009 02:18 PM
Disassemble KAF camera mount? newarts Pentax DSLR Discussion 7 03-06-2009 01:47 PM
disassemble old teleconverter and take glass out? fsdogwood Pentax Camera and Field Accessories 3 05-10-2008 07:16 PM
All times are GMT -7. The time now is 06:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
