05-24-2010, 08:04 AM   #1
problem with mamiya/sekor on spottie F?
I recently acquired an Auto Mamiya/Sekor 55mm/1.4 (non-sx) lens. I tried it on my Spotmatic F and it wouldn't screw in all the way until several tries. Is there any known issue with the compatibility with spotmatics? BTW, lens is great even wide open.
05-24-2010, 08:08 AM   #2
Ira
QuoteOriginally posted by ragamuffin1171 Quote
Spray some WD-40 on the lens threads, but hold it in such a way so it drips down and not into the lens.
Might just be some crud in there.
05-24-2010, 08:25 AM   #3
I'll try that. But when it wouldn't go in completely, it would spring back a little as if something is obstructing. I thought it was the rear element that was protruding, so I focused the lens to bring rear element away from the mount. After a concerning "click" right before the full mount, this thing is finally in securely.
05-24-2010, 09:18 AM   #4
pacerr's Avatar
Align a Pentax and the M-S lens and compare the position of the aperture lever mechanisms. I seem to recall that I had to remove something to adapt a Mamiya lens to the K-mount without interference.
H2
05-24-2010, 04:10 PM   #5
Your aperture pin may be a little longer than the Pentax version. Make sure that the meter switch is not pushed up when you are screwing the lens on.
k-mount, lens, mamiya/sekor, pentax lens, slr lens
Why no love for Mamiya Sekor? Shamwow Pentax SLR Lens Discussion 68 01-19-2019 04:16 PM
Does Mamiya/Sekor 50mm f1.2 really exist? ducdao Pentax SLR Lens Discussion 27 04-24-2018 01:33 AM
New Arrivals: Mamiya/Sekor 55/1.8 (Third of three) stevebrot Pentax SLR Lens Discussion 2 03-01-2009 10:42 PM
Mamiya/Sekor M42 lenses frederik9111 Pentax SLR Lens Discussion 8 03-23-2008 02:42 PM
All times are GMT -7. The time now is 07:25 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
