05-31-2010, 02:42 PM   #1
tamron 90mm f2.8 lens
hi, guys, i am interested in buying this lens.
one question is that what i can do with it except for potraits and macro? can i possibly use it to capture things that are very far away? thank you very much for any input!
05-31-2010, 02:44 PM   #2
Ira
It's a wonderful all-purpose lens. I have one.
05-31-2010, 02:52 PM   #3
I've had it before for another mount (Minotla) and it was my go-to lens for macro and portrait. Loved it then (and looking for one now). It even did ok with a 2x TC to go to 180mm (then to 270mm with the APS-C factor)
05-31-2010, 03:10 PM   #4
d3zzzz's Avatar
Great lens. Really, really sharp. You won't be disappointed.
05-31-2010, 03:47 PM   #5
DaniRo's Avatar
QuoteOriginally posted by shang Quote
... can i possibly use it to capture things that are very far away?...
very far away is a long shot , this is relative
it's a great lens, unless you whant to shot small birds with it or things that are really, really far away
05-31-2010, 03:58 PM   #6
wow! thank you guys! Dani, ur pics are amazing!
a dumb question, the lens is for FF cameras? so 90mm equals around 135mm? am i right? so that means it's actually the same as a 135mm focal length lens on a K-7? thanks a lot!
05-31-2010, 04:04 PM   #7
It's still a 90mm lens but gives you the same View as a 135mm. But you understood that right? As others have stated, you won't be disappointed with it. My only disappointment with mine is that I sold it years ago.
05-31-2010, 04:10 PM   #8
Marc Sabatella's Avatar
No. Whether or not the lens happens to work with FF cameras has *nothing* to do with it. All 90mm lenses produce exactly the same field of view on a K-7. It happens to be the same field of view that a 135mm lens would produce on a FF camera, biut that's of interest only if you happen to have extensive experience with FF cameras and know exactly what a 135mm field of view looks like. if not, you can completely forget you ever heard about crop factors. Whether the 90mm lens you mount to your K7 is made for FF or not doesn't change *anything*. Again, all 90mm lens have the same FOV on your K7, and the notion of a crop factor doesn't come into play unless you are comparing your K-7 to an FF camera.
If you have a zoom lens that cover 90mm, set it there, and what you see through the viewfinder will be exactly what the Tamon 90 will produce on the same camera.
05-31-2010, 05:55 PM   #9
Clinton's Avatar
It's a great lens. My only optical complaint with it is a little bit of purple fringing in bright light.
If I was buying this lens now, it would be a hard call between this and the WR 100mm pentax macro.
As far as usability, I do have some complaints. When you switch this into MF mode, you have to switch the camera over to MF as well, or it will still be engaged to the screw drive on the camera; so it's not quick shift like most of my lenses.
This lens extends out the front, way way out the front, and I expect it will collect dust on account of it.
The AF on the lens seems to be a bit overzealous in jumping between different points of focus. Sometimes I do have to play with it a bit to get it to focus on the item I'm interested in. I don't have another macro lens, so I don't know if this is just a side effect.
Still I picked mine up used cheap, it was my first experience with F2.8 glass, and overall I'm very happy with it.
05-31-2010, 05:57 PM   #10
Clinton's Avatar
The photozone.de site gives this lens a high review as well:
Tamron AF 90mm f/2.8 Di SP macro (Pentax) - Review / Lab Test Report
05-31-2010, 10:15 PM   #11
thank you very much for all the inputs, guys!
my goal was to find a long focal length lens to use together with da 17--70. i believe this is a good choice and so are the sigma 105mm and pentax 100mm.
06-01-2010, 03:39 PM   #12
Ira
I've mostly used mine in manual focus, and as said above, it does have a tendency to hunt for focus, even with the limiter properly engaged. However, this only happens on your first shot in a series.
I'm also not a huge fan of the push/pull, manual/autofocus operation on the barrel of the lens, because it's easy for this to unintentionally change just putting in and removing from your bag.
However, this is a minor inconvenience compared to what the lens can do. As long as you check the settings before pulling the trigger, you're cool .
However again, others here like the push/pull function.
06-01-2010, 05:16 PM   #13
geauxpez's Avatar
I can take or leave the push-pull function. The lens is brilliant.
I'm a dog person, but since someone took care of that already...
ISO: 400 f2.8 1/8 sec handheld...
06-02-2010, 02:33 AM   #14
As others has stated, you won't be disappointed. It's a very sharp lens and lovley for macro shoots
06-02-2010, 04:32 AM   #15
Excellent "all round" lens
It makes a good short tele, I wouldn't say that it is good for "very far away" but it is quite good for "not so far away"
Portrait and macro capabilities aside, it also does well on "normal" shots too.
edit: And I almost forgot to mention, it has excellent bokeh
NaCl(you won't be sorry getting this lens, it is quite versitile)H2O
k-mount, lens, pentax lens, slr lens, tamron 90mm f2.8
For Sale - Sold: Tamron SP AF 90mm f/2.8 1:1 Macro Lens dgaies Sold Items 5 01-03-2010 03:11 PM
Lens value question/inquiry: Tamron 90mm F2.5 joeyc Pentax SLR Lens Discussion 12 11-19-2009 01:45 AM
pentax ist ds and tamron 90mm SP 2.8 macro lens pentaxsteve Pentax SLR Lens Discussion 12 02-11-2009 06:08 PM
PENTAX K-A TAMRON SP 90mm F:2.5 MACRO 1:2 LENS FHPhotographer Pentax SLR Lens Discussion 3 12-10-2008 07:56 AM
Tamron 90mm Macro lens, First attempt Ed in GA Post Your Photos! 10 01-20-2008 08:09 PM
All times are GMT -7. The time now is 10:49 PM. | See also: NikonForums.com, part of our network of photo forums!
