Originally posted by Deni You should first make up your mind what are you really looking for in the upgrade.
Is your lens too short?
Is your lens not wide enough?
Are you looking for a faster lens?
Are you looking for a sharper one?
I probably wasn't specific enough, but the fact is that I just want an overall better lens of about the same range.
The range is fine -- I wouldn't mind wider, but definitely don't need longer. I'm perfectly happy using the 55-300mm for longer, especially with the image quality I'm getting out of it.
I'm not necessarily looking for a faster lens, but wouldn't mind it. The KX's high ISO performance is very nice, so a slower/darker lens doesn't bother me so much.
Definitely looking for sharper and just better overall image quality (color, contrast, etc.).
Originally posted by Deni You should review the images you've taken with your kit and see whether:
you're shooting mostly wide open (ie you need a fast lens).
you're either using the 18mm or 55mm more often (thus decide you you need a longer reaching or a wider lens)
you're not happy with the quality, like sharpness and contrast, of your kit lens.
money is burning a hole in your pocked :P
Myself i've found needing something wider than the 28mm the Sigma 28-70mm f/2.8 is offering me so I'm looking for a trade
I suggest you take a little bit longer time to evaluate your needs.
$400 buys you a nice used lens.
Since I do have the KX, I typically don't need to settle for shooting wide open since I usually don't need to, and bumping up the ISO and stopping down the 18-55mm seems to help the image quality more often than not. But the image quality (specifically sharpness and contrast) is nowhere near as good as the 55-300mm.
I always thought I was a superzoom type of guy (I've always owned Panasonic P&S superzoom cameras prior to my venture into DSLRs), but right after buying the KX I ran a utility against my entire photo archive, and was very surprised to see that the vast majority of my shots were in the 35-50mm range (35mm was the widest most of my previous cameras could go). I was shocked, but it was a good thing to know, as I will now focus most of my $ on the wide end, which is a doubly good thing since I'm very happy with how the 55-300mm handles the long end of things.
I don't think I need to evaluate my needs more -- I basically just a superior replacement for the 18-55mm range.
-- Chris
