Originally posted by mulder i wondered if pentax in the past made some wide angle lenses for the film...i would really love to buy a wide angle lens, but they waaaay over priced for me.A manual, old, "veteran" lens would be perfect to me, if i could find one...
The are of course many wide angle lenses made by Pentax for film cameras. But if you have a digital camera with APS-C sized sensor, then your sensor is 23.5mm long, while a 35 mm film frame is 36mm long, which is 1.53x longer. Therefore, a lens on a digital SLR will have the same field angle as one with a focal length 1.53x longer on a 35mm camera. For example, if you buy an SMC Takumar 28/3.5 lens -- a very common wide angle lens from the olden days -- you will end up with the equivalent of a 42.84mm lens on your digital camera, which is not especially wide.
So you have to get an ultrawide lens for it to perform as a wide lens on your digital camera. Unfortunately, 30 or 40 years ago, ultrawide lenses were not commonly used, so they tend to be rare and expensive. There were only two screwmount superwides made by Pentax:
- SMC Takumar 15/3.5 (23mm equiv.): good lens, but expensive, big and heavy.
- SMC Takumar 20/4.5 (30.6mm equiv.): cheaper than the 15mm, but not as good.
If you are looking for a cheap wide angle, you'd better opt for the Russian made Zenitar. It's a very good 16mm full frame fisheye, which becomes an all-purpose wide angle with a fair amount of distortion on a digital SLR. Software correction of the distortion is very easy to achieve.
Cheers!
Abbazz
