06-09-2010, 04:58 AM   #1
IQ difference between 300mm DA*, FA* and F*?
Hi everyone - first post from a long time lurker!
I'm currently shopping for a 300mm lens which I will be using for wild life photography, and I have three candidates - the DA*, FA* and F* (not including the 2.8 versions). Iím trying to figure out if there is an IQ difference between these three, and hoping someone could help me out. I keep reading reports about the DA* being a bit soft wide open, but havenít read anything similar about the FA* or F* lenses. At the moment it seems the DA* lenses are easier to find and at a cheaper price than the older FA* and F*.
Any input about the difference between these three lenses would be much appreciated!
Thanks!
Patrick
06-09-2010, 05:07 AM   #2
Asahiflex's Avatar
I've never compared them directly, but I would choose between the F* and the DA* as the FA* does not have a tripod collar. This is not a problem if you want to use the lens strictly handheld, or try to find/make your own tripod collar.
BTW: I have the F* and I would only replace it with the DA* if I badly wanted the weather sealing (and I do not).
06-09-2010, 05:11 AM   #3
netuser's Avatar
Get the FA*, then the others. (get also a converter 1.4x)
About the tripod colar, you can use a third party colar for the canon 70-200/4 lens that is the same fit that the FA*300 lens as stated here in the forum on other threads.
(I'm using now a FA*400/5.6)
06-09-2010, 05:23 AM   #4
Moderator Emeritus
Sorry Ashahiflex but he FA* tripod collar "issue" is a non starter. Easily solved with a $20 Canon 70-200 tripod collar found on Ebay everyday. It even matches the silver colour. I have one on mine.
That being said, this is not a heavy lens. I don't use the tripod much at all and is easily hand held. The F* is a bit lighter.
As for the lens comparison, there's no difference between the F and FA versions optically. I can't speak to the DA* though which has the advantage of weather seals.
All 3 are ED lenses as well. My FA* is sharp wide open without any reservations. Look at these figures.
If I had around $1000 to spend on a lens, which would I buy? The F* or FA*. Just because the DA* is cropped image circle although users report that it will do fine on a FF body. Second I just don't have any faith in the current SDM motors. Screwdrive is fast enough and has 20 years of reliable service.
06-09-2010, 05:24 AM   #5
ivoire's Avatar
You will be very pleased with any of them. They all offer excellent image quality. The DA* has the weather seal advantage if you need it.
06-09-2010, 05:29 AM   #6
Moderator Emeritus
See this thread on an FA* collar https://www.pentaxforums.com/forums/field-accessories/32386-fa*300mm-f4-5-tri...oods-well.html
06-09-2010, 06:28 AM   #7
Clinton's Avatar
QuoteOriginally posted by Asahiflex Quote
The lens is lighter though, so it doesn't pose a problem for me, even when mounted on my cheap tripod.
Also since it's lighter, it's easier to pack up into the mountains with me.
I dont have the DA* to compare, however, I'm told that the FA* is sharper.
06-09-2010, 07:09 AM   #8
Asahiflex's Avatar
Oh, I knew about the 3rd party collar, but not everyone wants to fiddle around with 3rd party solutions (yikes, a canon strangles my Pentax! )
On a different note: is it really true that older AF glass is often better because the lens elements and/or coatings have lead in them (which is now forbidden due to ROHS regulations)? I keep hearing this. And if so, was this indeed the reason for Pentax to drop the FA* line completely? I.e. they were forced to.
06-09-2010, 07:12 AM   #9
Moderator Emeritus
I might be wrong but I think the Lead issue predates the FA* series *the 300mm was launched in 1991).
So hard to know if that really is the difference or not.
06-09-2010, 07:20 AM   #10
Asahiflex's Avatar
QuoteOriginally posted by Peter Zack Quote
Nope, the ROHS regulations were adopted in 2003 by the EU. So it's fairly recent. On Bojidar Dimitrov's excellent K-mount page I see that the FA*'s were discontinued in 2004, so 1+1=2?
06-09-2010, 07:49 AM   #11
Moderator Emeritus
There you go. Maybe that's the issue and reason these are such good lenses. I'm not too worried about lead in the glass. I don't lick my lenses clean.....
06-09-2010, 09:17 AM   #12
netuser's Avatar
.... I don't lick my lenses clean.....
Neither do I
06-09-2010, 10:11 AM   #13
I found this review of the DA*300:
Pentax DA* 300mm f/4 Lens Review
Looking at the images at the bottom of the page, there actually seems to be a significant difference between f4, f8 and f16. Copied from the review:
"Unlike the FA* 300mm, which was known for fairly uniform sharpness across the board, the DA* 300mm is a bit of a roller coaster ride in this regard. In examining 100-percent crops from our test chart shots, both edge and center are noticeably soft at f/4."
Interesting!
300mm, da*, fa*, iq, iq difference, k-mount, lenses, pentax lens, slr lens
Whats the Difference between the Pentax 50-135mm vs the 50-200mm or 55-300mm rustynail925 Pentax SLR Lens Discussion 2 03-12-2010 11:47 AM
What's the difference Dxn2 Troubleshooting and Beginner Help 6 12-26-2009 06:55 PM
Difference between PZ-1 and PZ-1P Stevopedia Pentax Film SLR Discussion 9 11-04-2008 11:57 AM
K and A difference JCSullivan Pentax SLR Lens Discussion 15 03-04-2008 01:02 AM
What's the difference between ... kjao Pentax Camera and Field Accessories 12 06-17-2007 08:57 AM
All times are GMT -7. The time now is 11:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
