Originally posted by kiron Kid My apologies for resurrecting an older zombie thread. However, I am intrigued by this lens. I already have the f/2.8 AT-X version, and the Tamron SP 20-40 f/2.7-3.5 lenses. Any opinions or experiences when compared to the two lenses that I mentioned?
Which AT-X f/2.8?
I have the 24-40mm, which is uncommon and and very good, probably the best Tokina I own.
I don't have the Tamron, sorry, but I can tell you that the AT-X 3.5-4.5/20-35mm (first version) I own is my go-to lens if I need a wide angle zoom for my Pentax K-1.
Keep in mind that I use primes, mostly manual focus, 90% of the times, which means that I have never spent on zooms the kind of money I spent on primes. Zooms are for travel photography, when the bag has to be relatively small and/or there is a certain risk of theft or damage. Which means that zoom cannot be too expensive...
Another characteristic is portability. Zooms cover different focals using little space.
For example, the few times I really needed a long AF zoom, I have often used the AT-X 80-400mm instead of the Sigma 120-400mm, even if the Sigma is much better, cause the difference in size is relevant. The Tokina goes into a "normal" bag, the Sigma does not.
Back to the 20-35mm, I took great nature shots with it. Never architecture, so I don't know about distortion. Stopped down a couple of clicks it's definitely sharp enough for large prints or publication.
I would definitely advise buying one if you need a decently priced AF zoom that covers all the most used wide angle focals.
