I must have a good copy of the 300mm f2.8 lens. I bought it new, it is the Ex DG Apo, about 6 months old now. But at 2.8 it is great close. But stopped down to 3.5 to 4 it is absolutly stunning.
And that goes for the T.C's. It follows the lens exactly. At 4.9 with the 1.4 T.C. It doesn't get any sharper. At F7 with the 2.o T.C. It is at it's sharpest.
Here is a pic I took last week.
I use the lens on a gimble mount almost always for good sharp and consistent pics. But with the 1.4 and shake enabled on the camera it is very good also. If you can punch up the shutter speed. I am getting old and have a hard time holdint it for very long.
Many times with the 300 and the 2.0 attached i focus manually first on the subject then switch over to auto focus and it hits very fast. If not sometimes it is very slow. In low light it is a must to manual focus first I have found on my copy. But then it will hit after MF is close usually.
When used properly I don't see how the eye can pick up anymore detail.
I have many pics this good and better.
But I am thinking seriously about getting the 500mm f4.5 because with a T.C. on a pentax it will give me a 700mm lens. with minumum drop off in imige i hope.
With the 1.4 T.c. on the 300mm it is better but you must get very close to birds.
That is my copy if the 300 mm f2.8.
If the O.P. will PM me or give me links to your pics with the 500mm and the 500 with the 1.4 attached i would very much appreciate it.
This is with the 300mm + 2.0T.C. F7 and -.7.
