06-11-2010, 08:04 PM   #31
Praestigium's Avatar
QuoteOriginally posted by dantuyhoa Quote
Get a Vivitar Series One 105/2.5 Macro .
oicwutudidthar
06-12-2010, 09:01 AM   #32
NeverSatisfied's Avatar
"Good" working is a relative term. If you want more than 1:1, you're dealing with inches. How many inches depends on focal length - 1:1 at 200mm is achieved at a much longer working distance than 1:1 at 50mm. So the longer the focal length the better as far as that goes. But you're still going to need skill and patience, as we're talking a matter of maybe 6-8 inches for 1:1 at 200mm, versus maybe 1-2 inches for 1:1 at 50mm.
That's a nice thing about the use of a closeup lens like the Raynox (and reversing stacks are similar in principle, I guess - just a lot more awkward to deal with). Unlike extension tubes, they provide more magnification with longer focal lengths. So if you've already got a 200mm lens, any attachment that makes it 1:1 means you'll have a "decent" working distance by macro standards. Whereas trying to achieve the same magnification starting with a 50mm lens means much smaller working distances.
The DA*300 has a much closer minimum focus distance than some of the older Pentax 300mm lenses. I like this lens a lot and it with just a little cropping it can give pretty good results, but it's not really "macro". What do you think of a Raynox 250 on this lens?
Meanwhile, a lot of my lenses (including the wonderful D-FA 100 WR Macro) have no aperture ring and of course Kenko no longer makes their auto extension tubes in Pentax mount. (Why???) BUT, I think I've found an uber-cheap solution, just ordered a 49mm-49mm reversing ring for about $5. I'll be trying the F50/1.7 and FA35/2, reversed on the D-FA 100. Can't wait to try that!
So what is the opinion about the 300 + Raynox? I'm just thinking it would offer very good working distance...
06-12-2010, 09:06 AM   #33
One more idea!
Hey what about reversing either the F50 or FA35 on the DA*300? Whaddya think? I've got enough step-up rings, might vignette like crazy though (49 up to 77!).
06-12-2010, 10:41 AM   #34
QuoteOriginally posted by NeverSatisfied Quote
Don't know about 300 + Raynox.
But here's a test photo of DA* 60-250 (at 250) + Raynox 250. The pencil lead on the left is 5mm. Distance is about 3 ft.
For comparison, here's a 1:1 photo from the Sigma 50mm macro. Distance is about 3 in.
06-12-2010, 02:02 PM   #35
Hhmm, that 60-250 + Raynox looks pretty good! Thanks SOldBear. Do you use that combo much?
Oh,,, after a search I see the Raynox only accomodates up to 67mm filter diameter. Too bad.
06-12-2010, 04:43 PM   #36
QuoteOriginally posted by Praestigium Quote
@Marc: I think I've finally grasped what the Raynox does. Assuming I invest in a macro lens, it would be wiser to grab/use extension tubes instead of the Raynox on it?..............
The problem with the Raynox is that it destroys sharpness at the edges. There's a circular area with diameter equal to the height of the frame in excellent focus, but the perimeter is quite soft. Here's an example with a Tamron 90:
Without the Raynox the image is sharp at the edges - trust me, I didn't want to burn the bandwidth width to show you.
This often doesn't matter at all unless you are shooting really flat subjects like stamps or integrated circuits. For life macros of 3D subjects the edges seldom matter because the DOF is so shallow.
Dave
PS I don't mean to dissuade you from getting a Raynox. I use the DCR 150 with my DA 55-300 more than my fine macro lenses.... Plus it is so easy to carry in one's kit! The working distance of 8" is pretty good.
06-12-2010, 04:50 PM   #37
Simply reversing the DA 18-55 kit lens does a creditable job with macros. You can take control of the aperture by slipping a small PVC or rubber tube over the aperture lever - friction with the lever shield will hold the aperture lever in place.
Dave in Iowa
PS "clearance" = working distance
06-12-2010, 04:54 PM   #38
RioRico's Avatar
Think, STEP-DOWN RING (~US$5).
06-12-2010, 06:55 PM   #39
Hey why not!? If I was gonna try to reverse an F50 (49mm) onto my 300, stepping down from 77mm to 67 is certainly worth a try! (Already have that ring, too!) Thanks!
06-12-2010, 07:41 PM   #40
Ok guys just to clarify guys, I want to buy a reverse ring for my two lenses.
The Pentax 18 - 55 has no aperture ring and is 52mm
The Sigma 28 - 90 has an aperture ring and is 55mm (it also has a macro "switch" on the lens)
What measurements should the reverse ring be and which lens should I make the primary?
Thanks!
06-12-2010, 07:46 PM   #41
yeatzee's Avatar
Keep in mind, you will probably be disappointed IQ wise using sub par zooms for reversing
06-12-2010, 07:53 PM   #42
What do you suggest then? Buy a true macro lens and then go about using a reverse ring?
06-12-2010, 08:00 PM   #43
yeatzee's Avatar
Its all about primes
If you plan on only reversing that buy some cheap primes or just one prime and some manual extension tubes.
06-12-2010, 08:10 PM   #44
Understood!
Any recommendations? I have a $300 budget :S
06-12-2010, 08:26 PM   #45
yeatzee's Avatar
if i were you, i would get my feet wet with a K/M 50mm F/1.8/F/1.7 and M/K 28mm F/2.8/F/3.5 and some extension tubes. These shouldn't cost you much and will give you a wide variety of magnification possibilities.
These primes are essential in everyday shooting and work great as reversed primes for macro also.
31mm, guys, k-mount, lens, macro, macro lens, pentax, pentax lens, slr lens
Thinking on a new Macro lens. Advice? Ouroboros Pentax SLR Lens Discussion 15 04-15-2010 05:04 PM
Please advice (macro lens) Recercare Pentax SLR Lens Discussion 5 02-19-2010 10:30 AM
Advice on a macro lens please (Australia) Just Me Pentax SLR Lens Discussion 26 01-04-2010 05:11 AM
Advice on Macro lens Misty Pentax SLR Lens Discussion 14 03-04-2009 03:46 PM
Getting a macro lens and could use advice. dws1117 Pentax SLR Lens Discussion 22 06-15-2008 06:53 PM
All times are GMT -7. The time now is 04:17 AM. | See also: NikonForums.com, part of our network of photo forums!
