06-13-2010, 03:17 PM   #1
yellowed lens or SMC coating
hi. i have a SMC PENTAX-M 1:1.7 50mm lens that appears clear when looked at head on, but when viewed from the side has a gold tint. is the color i am seeing the SMC coating or is it the yellowing of old pentax glass i see some people posting about? ive bought a fair number of k mount cameras from thrift stores and have some duplicate glass to sell, and if this lens is yellowed i want to be able to describe it correctly if i post it for sale. thanks!
btw, i did take several picutres with this lens, and the images turned out fine.
06-13-2010, 03:41 PM   #2
Mechan1k's Avatar
Lens yellowing is really noticeable when looking directly into the lens itself. And ususally when shooting your images will have a warmish tone to them.
I have seen a number of angled shots of lenses with different coatings and I can definitely say that it'd be the SMC coating causing the Gold-glow ... I have seen it with my FA50 on different angles as well.
06-13-2010, 05:54 PM   #3
davidreilly3207's Avatar
Set it in bright sunlight for a couple of days. If the yellow goes away, it was yellowing.
06-13-2010, 07:08 PM   #4
must be SMC
had the lens sitting in the windowsill most of the week, and no change, so it must be the SMC coating. ive never noticed such a pronounced color with my SMC Pentax A glass
06-14-2010, 04:08 AM   #5
Ben_Edict's Avatar
QuoteOriginally posted by mnseawa Quote
SMC is a name that Pentax used for decades. But the coatings applied, changed over time. So the SMC on you9r M-lens is probably very different from the SMC on your later A-lenses.
Also, the yellowing of some lenses was to my knowledge limited to a few old Takumar lenses with Lanthanum glass. Later M-lenses don't use that type of glass and thus won't get yellow over time.
Ben
06-14-2010, 06:23 AM - 1 Like   #6
It is also difficult to know who often and how much Pentax changed that formula over the years. Its unclear if those records exist. I also suspect that the formulation of the coatings may have been different for certain lenses as well.
06-14-2010, 06:50 AM   #7
boriscleto's Avatar
This is from another thread.
AFAIK K-Mount lenses are not subject to yellowing. You can't tell if a lens is yellowed just by looking at it as the coatings add some color to the lens. You can tell a lens is yellowed by mounting it to a camera and pointing it at a white surface. If it looks yellow instead of white it has yellowed.
The following screw mount Takumars are known to yellow:
Part No. Model
43931 1:2/35mm Super-Takumar (49mm filter)
43932 1:2/35mm Super-Multi-Coated Takumar (49mm filter)
37800 1:1.4/50mm Super-Takumar
37801 1:1.4/50mm Super-Takumar
37802 1:1.4/50mm Super-Takumar
37902 1:1.4/50mm Super-Multi-Coated Takumar
37982 1:1.4/50mm SMC Takumar
The earliest 1:2/35mm Super-Takumar (part nos 368, 43680, with 67mm
filter) and 1:1.4/50mm Super-Takumar Model 1 (part nos 358, 35800)
with 8 elements) are NOT subject to yellowing.
The 1:1.4/50mm Super-Takumar Model 1 8-element lens can be easily identified by:
• Looking at the position of the red infra-red focusing mark which
lies between the f4 depth of field marker and the infinity mark.
On the later 7-element lenses the infra-red focusing mark lies
between the f8 and f4 depth of field markers.
• The protruding rear element which lacks the metal retaining ring
found on the later models.
There are many more 7-element lenses than the 8-element version.
No other screw mount Takumars are known to suffer from yellowing.
06-14-2010, 02:13 PM   #8
Just1MoreDave's Avatar
The reflection from the front coating varies, depending on shape of the front element, what it's reflecting and the coating formula. These photos are typical of what I get from the M50/1.7 and the M or A 50/2:
To check for yellowing, skip reflections. Look through the lens at a white piece of paper. Yellowing will be visible, and obvious when compared to a similar non-yellowed lens.
glass, k-mount, lens, pentax lens, slr lens, smc
Compare the lens coating of Takumar-F 70-210mm and smc Pentax-F 70-210mm jcdog2006 Pentax SLR Lens Discussion 13 02-19-2010 08:16 AM
How to? - coating shots axl Photographic Technique 0 05-23-2009 02:41 PM
Etched coating on lens??? zoeybird Pentax SLR Lens Discussion 14 01-24-2009 05:09 PM
Why does sunlight clear yellowed lenses? germar Pentax SLR Lens Discussion 15 06-09-2008 06:45 PM
SMC coating. How to clean Pentax lenses? Edvinas Pentax SLR Lens Discussion 7 10-27-2007 04:44 AM
All times are GMT -7. The time now is 06:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
