Originally posted by Miguel Blue,
Re: Bigma use, I am referring to physical space for backing up and getting a wider field of view with a single focal length lens that the OP was desiring. The Bigma with 50mm on the wide end is excellent for action close to the sidelines where I tend to shoot from. Unfortunately the optical quality of the lens is pretty average and the AF is worse, but that's what the low end gets you.
Judging from your first shot, I would disagree about 400mm being unnecessary. I assume that the action you are covering at 300mm is near field. How 'bout action a little closer to the goal post or behind the goal post? Your example is a fine shot indeed for our context here, but paid work would demand a much closer capture.
Same for the others, during a game you have to be able to capture action that's not always close to one's seats--a stable location. I assume the OP will roam some if he can. Isn't that SP a manual-focus lens? It's fine for that second prior to the snap where the offense cannot move, but for action honey shots, AF is a requirement to me. And that's where those other platforms come into play.
M
The 1st shot was from the "nickel" seats, way the hell up. I still say the Bigma is a dog for sports and way too big to boot because it is way too big for a spectator lens and not all that great for the side line.
As far as action with a mf lens, you are joking aren't you? The above shot of Osceola & Renegade was with MF. This sequence is from a play out of the Gun with the SP 180mm.
Botched P.A.T. sequence with the SP:
As far as "paid" shots go, all shots aren't face shots nor do the vast majority end up in SI. Furthermore, its good to get team shots during sporting events. As I said in the previous post, the shots were from the stands. A side line pass changes things. I guarantee you the night I had my SP 180 out at the game, the Pros on the field were trying to get me dragged out of the stands and thrown out but I had a little more clout than they anticipated.
Edit: The AF may or may not increase my success rate. Missed focus is missed focus whether it is by the camera during a spray and pray or mf sequence.
