Originally posted by ronald_durst Its all kinda bleak for me but i think i remember seeing an adapter that will allow a canon or nikon lens to fit on a pentax. Is there such a thing? Is it any good?
I've only ever seen a Nikon F to Pentax K. but then it got stolen when I was testing it out at a camera shop. (and yes I found out I indeed lost infinity focus which is to be explained.)
Unfortunately, both mounts F and FD (EOS is pointless because you NEED EF mount to control EOS lens.) aren't compatible.
#1 Canon FD - Flange distance (lens to film distance) is shorter than that of pentax K so when if you do fudge up an adapter ring some how, you will lose infinity + your longer focus ranges + more of your mid focus ability due to thinkness in adatper. the only way is to have an adapter that utilizes a optical correction element...which spoils your lens IQ...and frankly Canon FD ain't popular enough for people to make them.
#2 Nikon F - The nikon f flange is actually longer than Pentax K by like 1mm or something. so if you stick a nikon lens directly onto your K Mount and hold it there with your hand, you still retain all focus ability. However, by adding an adapter that connects bayonet..to bayonet.. you've just spoiled the flange difference by literally 'extending' the Pentax Mount by a few mm because you are setting the Nikon lens farther away. When you exceed 1mm or whatever the difference in the native mounts are, you lose infinity focus.
Side note - I've begun to see Minolta film to Minolta AF (Maxxum5d/7d,Sony a100) converters on ebay. these come with a built in correction element. So whether those will have a profound effect on IQ remains to be seen.
For the time being, just enjoy that Pentax K is still the only mount as of yet that retains backwards compabitility with all its lenses.
Nikon's current F mount status is considered puesdo-backwards compatibility because they nerfed all metering capability with older f mount lenes in the all their dSLRs save their pro line up. (D1, D200 and D2)
