06-18-2010, 06:25 PM   #1
Newbie Qustion-what difference a "P"
Does it mean the obvious? Is one of these lenses built with of metal and the other plastic?
What's the difference?
SMCP-DA 18-55mm f/3.5-5.6 AL Lens
and
SMC - DA 18-55MM F3.5-5.6 AL WR Lens
and if BH lists it this way: "DA 18-55mm f3.5-5.6 AL WR " which one is that?
While I'm at it, what's WR?
06-18-2010, 06:29 PM   #2
Otis Memorial Pentaxian
photolady95's Avatar
WR stands for Weather Resistant. AL is the older version, of those lenses. I have the AL ll which is newer than the AL, and was told the sharper of the two. I assume the WR is sharper still.
06-18-2010, 06:42 PM   #3
Blue's Avatar
QuoteOriginally posted by photolady Quote
The AL II and WR versions should be the same optically. The original AL version had 12 optical elements arranged into 9 groups and the II, WR and DAL have 11 elements arranged in 8 groups.
QuoteOriginally posted by nelsh Quote
and
P stands for Pentax.
Only the D AL version of this lens has a plastic mount and also lacks quick shift.
Edit: There is a "sticky" on a thread discussing these very things.
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/89036-differences-between-various-18-55mms.html
06-19-2010, 09:31 AM   #4
Marc Sabatella's Avatar
As mentioned, P standads for Pentax. it is probably part of the official names of all lenses Pentax makes, but hardly anyone lists that in the description becaue we all know these are Pentax lenses. So don't ever get hung up on one lens listing the P and another not. Most DA lenses (except Limiteds) are at least partially plastic, but all have metal mounts except the ones listed as "DA L". And don't confuse that with "AL", which is also something that applies to a lot of lenses and doesn't really differentiate one from another.
The real difference between the lenses you are talking about is WR, and as others have answered, that's weather resistance.
18-55mm, f3.5-5.6, k-mount, lens, pentax lens, slr lens, wr
"Hunger for a DA*50-135?" or "The DA*50-135 as a bird lens!" or "Iron age birds?" Douglas_of_Sweden Post Your Photos! 4 08-13-2008 06:09 AM
What difference does "D-Range 200%" really make? amateur6 Pentax DSLR Discussion 28 05-06-2008 09:22 AM
What is difference "APO" and "ED" glass in a lens? kathyk Pentax SLR Lens Discussion 4 03-06-2008 08:59 AM
Difference between a macro and "regular lens" weatherwise2 Pentax SLR Lens Discussion 3 01-01-2008 04:40 AM
difference between "Bigma" versions? rfortson Pentax SLR Lens Discussion 2 01-31-2007 07:43 PM
All times are GMT -7. The time now is 03:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
