06-19-2010, 03:04 PM   #1
M42 Lens Finish Lacquer/ Anhydrous Methyl Alcohol
Will Anhydrous Methyl Alcohol damage the black lacquer finish or the front element on the M42 screw mount lenses: 28mm 3.5 Super Takumar, 35mm 3.5 super Tak, and 135mm 3.5 Super Tak? I have some of this and was wondering if it was safe to use.
06-19-2010, 08:54 PM   #2
Wheatfield's Avatar
It might. Quite honestly, the best cleaner you can get for lens bodies is tap water. Most of what you'll get on your lens will come off with it. A damp microfiber cloth is an amazing lens cleaner.
You want it well wrung out though.
For glass, a microfiber cloth and breath seems to work well.
06-19-2010, 10:02 PM   #3
Awesome! I have tap water, microfiber cloth, and breath handy. Thanks
06-20-2010, 01:32 PM   #4
Lloydy's Avatar
To get horrible crap off a lens I use wet wipes, just let them dry out a bit so the soapy stuff doesn't run inside the lens.
I've cleaned lenses that were sticky and disgusting to great effect with them.
06-20-2010, 01:46 PM   #5
I have used methanol to clean fungus off the elements of a Super Takumar lens. It didn't do anything to the coating. Same can be said about the paint. The lens is fugus free and takes great photos.
Why did I decide to use methanol? Well, it is because I read on a bottle of Eclipse fluid that it "contains methanol"!
06-20-2010, 11:43 PM   #6
Thanks to everyone!
06-21-2010, 06:07 PM   #7
I have used isopropol alcohol to clean a filthy lens body with good success. I have also used glass cleaner (Windex). Be aware that use of any cleaning solvent (including soapy water) has the potential to "lift" painted lenses markings off of the barrel. Embossed numbers are easily repaired using a lacquer pen or paint crayon, but non-embossed numbers are gone forever...
06-21-2010, 06:35 PM   #8
Blue's Avatar
Just be sure that if you use Windex, that it doesn't have ammonia in it.
06-22-2010, 09:33 AM   #9
Yes, Windex does have ammonia in it. So do many other cleaners. I used it as a last resort on a lens body that had so much tobacco film that it was gummy feeling.
alcohol, k-mount, m42, m42 lens, methyl, pentax lens, slr lens, tak
For Sale - Sold: Free - lens, lens case, m42 extension tube heliphoto Sold Items 3 11-30-2009 05:55 PM
For Sale - Sold: Industar 50-2 50mm f/3.5 Soviet M42 lens + M42 Adapter 65535 Sold Items 10 11-27-2009 04:18 PM
Finish up the series from this week Jimbo Post Your Photos! 6 08-08-2009 10:06 AM
I'd like to capture a subtle finish on a guitar Aegon Post Your Photos! 7 01-17-2008 03:26 PM
Silver Limiteds finish durability barondla Pentax SLR Lens Discussion 5 05-09-2007 04:25 AM
All times are GMT -7. The time now is 09:54 AM. | See also: NikonForums.com, part of our network of photo forums!
