06-21-2010, 04:09 PM   #1
300mm vs 60-250mm
I currently have the sigma 70-200 f/2.8 lens that I got to use for taking wildlife and kid/football picks. I'd really like something with a little more range than the 200mm. What would you guys recommend the 60-250 or the 300mm? My only concern about the 300mm is that it won't be as verstatile as a walk around lens for wildlife.
06-21-2010, 04:14 PM   #2
ivoire's Avatar
What about the Sigma 100-300mm?
06-21-2010, 04:41 PM   #3
Id really like to try a pentax lens - both lenses I have now are sigma's. No complaints really, just want a Pentax for a change.
06-21-2010, 05:11 PM   #4
I had both 60-250/4 and 300/f4 DA*s, only complaint I have on the 60-250mm/4 is not long enough for me while I am shooting wildlife. Well, sometimes 300mm might not be long enough, depends on the situation.
on the other hand, 60-250/4 was my fav. walk around lens...
06-22-2010, 02:44 AM   #5
adwb's Avatar
QuoteOriginally posted by thechucked Quote
I currently have the sigma 70-200 f/2.8 lens that I got to use for taking wildlife and kid/football picks. I'd really like something with a little more range than the 200mm. What would you guys recommend the 60-250 or the 300mm? My only concern about the 300mm is that it won't be as versatile as a walk around lens for wildlife.
I had up till recently a Sigma 28-300 which was due to the focal range a great walk round lens. I believe Sigma still make them. However I always found the higher magnification end a bit soft and at 300 all over soft. I did not realise how much till I tried a Pentax 55-300 DAL lens the difference between two images at 300 was very noticeable in the sharpness of fine detail like birds plumage, wall textures etc.
I know the DAL is a "cheap"kit lens but I would suggest at the price well worth looking at as It is price wise comparable to the Sigmas.
Alistair
06-22-2010, 07:29 PM   #6
Reportage's Avatar
how about getting Sigma 1.4x or 2.0x teleconverter to extend the 200 f/2.8 range however will lose about one stop of light. seeing that the alternatives are also f/4, might give it a try.
06-23-2010, 05:09 AM   #7
Lowell Goudge's Avatar
which version of the sigma.
All but the HSM version work very well with sigma's EX-DG tele-converters
the TCs cost about $200 each for the 1.4x and 2x versions. this way you get length when you need it, but retain the F2.8 when you don't
06-23-2010, 08:47 AM   #8
I've got the Sigma 70-200mm f/2.8 DG Macro HSM II AF . I checked the sigma site a while back it wasn't listed on the compatability chart for the 2x convertor but now it is :Lens - Teleconverter Compatability Chart .
I tried a teleconvertor from BH and while back with the 70-200 and didn't work at all..no af, no manual focus confirmation, couldnt access camera menus with it attached...so I kinda gave up on the TC route.
06-23-2010, 09:56 AM   #9
Marc Sabatella's Avatar
Since this question is about lenses, I'm moving it to the lens forum.
06-23-2010, 10:43 AM   #10
SpecialK's Avatar
250 is not really much more than 200 and the wide end is not what you want, so I'd go with the 300 if you are only choosing between those 2 lenses.
06-23-2010, 05:36 PM   #11
Clinton's Avatar
The 60-250 is surprisingly lightweight. It makes it easier to pack around to be sure.
300mm, k-mount, lens, pentax lens, slr lens, wildlife
18-250mm or 55-300mm? NecroticSoldier Pentax SLR Lens Discussion 10 04-09-2010 10:28 AM
DA 55-300mm vs. DA* 60-250mm? redpigeons Pentax SLR Lens Discussion 30 02-17-2010 07:59 PM
PENTAX 18-250mm VS QUANTARAY 70-300mm@250mm charliezap Pentax SLR Lens Discussion 7 02-08-2010 11:38 PM
DA 55-300mm: much of an upgrade from DA 18-250mm ? aerodave Pentax SLR Lens Discussion 19 11-17-2009 11:36 AM
All times are GMT -7. The time now is 11:57 AM. | See also: NikonForums.com, part of our network of photo forums!
