06-22-2010, 07:42 PM   #1
K10D not recognizing DA* 60-250
Recently my K10d has stopped automatically recognizing my 60-250 lens. It does recognize my other lenses. I cleaned the contacts, but it still doesn't recognize it. It does recognize the focal length. Anyone have any ideas what could be wrong?
06-22-2010, 07:43 PM   #2
Ole
Ole's Avatar
What do you mean by "not recognizing" that lens?
06-22-2010, 07:45 PM   #3
SpecialK's Avatar
I'm not one who thinks a "firmware update" solves everything, but I think a firmware update may do it. The lens is not in the camera's database (?).
This is a problem with some photo editing software, too (Elements from experience).
06-22-2010, 07:45 PM   #4
QuoteOriginally posted by Ole Quote
It does not tag the pictures with the lens that took the picture. I'm using Lightroom 2.7.
06-22-2010, 07:49 PM   #5
Ole
Ole's Avatar
QuoteOriginally posted by opiet70 Quote
That's what I suspected. It is a software problem. Your version of Lightroom is older than the lens and doesn't know the code of the lens.
The camera does not have a built-in lens database, it just reads a numerical code from the lens and embeds it into the EXIF for Lightroom to interpret.
06-22-2010, 07:50 PM   #6
It did recognize up until about 2 weeks ago in Lightroom
06-22-2010, 07:51 PM   #7
Ole
Ole's Avatar
Then try to reinstall lightroom. Lightroom's database could've become corrupted.
If that doesn't fix it, I can only think that the lens is at fault - the lens code for some reason cannot be read anymore by the camera.
06-22-2010, 07:52 PM   #8
Ole,
I don't think it's Lightroom since it worked previously. I did update the firmware about 4-5 months ago on the camera. I updated Lightroom to 2.7 a couple months ago also and it worked fine until the last couple weeks. I'm not sure why it stopped working since that point...
06-22-2010, 07:52 PM   #9
I'll try that. It is something I hadn't thought of.
06-26-2010, 11:01 AM   #10
well, I've verified the lens doesn't export exif data to either Lightroom or Pentax's software. I contacted Pentax, who asked me to update to firmware (there was one upgrade). I updated the firmware and it still is not recognized in the exif data. Needless to say, I think I'm having a problem with the lens. I'll update after Pentax returns my e-mail just in case anyone else is/may have this problem.
06-27-2010, 02:25 PM   #11
I have the same problem with a K10D, K-7 / DA* 60-250mm combination in both LR 2.7 and 3.0.
However, PhotoME *does* find the DA*60-250mm signature in the EXIF data.
So I guess it is a Lightroom problem, not a camera / lens problem.
Contact Adobe, not Pentax.
Cheers, Bert
06-27-2010, 02:41 PM   #12
QuoteOriginally posted by bymy141 Quote
Then why doesn't Pentax's photo viewer read the exif data? It reads my other Pentax lenses just fine
06-27-2010, 02:54 PM   #13
Wheatfield's Avatar
Ole,
Lightroom 2.7 doesn't recognize the 60-250.
It also doesn't recognize the *55/1.4
My previous versions haven't recognized these lenses either.
06-27-2010, 03:11 PM   #14
You have to understand that the camera just stores a number under "lens used" in the exif data. It is then up to the program to know that the DA *60-250 is identified by the number. If the lens is too new then it won't get recognized. Often companies are a little slow about updating these databases any way...
06-27-2010, 06:52 PM   #15
Wheatfield's Avatar
In the case of Adobe, it's been nearly a year, and no update recognizing the 60-250 or 55.
k-mount, k10d, pentax lens, slr lens
Pentax 18-250 and k10d overexposure problem j1mallen Pentax SLR Lens Discussion 2 07-14-2008 05:11 PM
Strange K10D + Pentax 18-250 behavior henzo Pentax DSLR Discussion 1 06-03-2008 05:54 PM
New Pics with the DA 18-250 and k10d ronald_durst Post Your Photos! 3 05-21-2008 09:52 AM
K10D + Tamron 18-250 xxlyyk Pentax SLR Lens Discussion 1 08-14-2007 10:27 AM
Tamron 18-250 for K10D Papou Pentax SLR Lens Discussion 12 06-29-2007 10:34 AM
All times are GMT -7. The time now is 03:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
