I have to agree with a previous poster, going wide on a crop and long on a FF doesn’t make sense.
I think your existing gear may be clouding your judgment on what your new purchases should be. You need to consider what you would buy today if you had nothing. Then set about executing to that plan. Eg, if you wanted both FF & Crop, would you set out to purchase the bodies from separate manufacturers? Possibly not. Would you set out to buy a crop camera for <200mm work and a FF for >200mm? Would you go out and buy both the 77mm & the 85mm Pentax lenses?
Like I said, figure out you ideal “system” and go with that.
