06-29-2010, 12:26 AM   #16
yeatzee's Avatar
QuoteOriginally posted by gybp Quote
Hi, i actually have these lenses,
50mm f1.7, 50mm f1.2, 28mm 2.8, 18-55 kit lens, 70-210 f3.5
as you see i have no macro (actually i have a 90mm tamron macro but for my nikon camera that i dont use that often).
The thinbg is that i want to shoot macro and i dont want to buy a new lens, i read somewhere about the reverse lens ring. What do i need to buy in order to make this work? no DIY stuff please, thanks a lot!!!!
No DIY? If you want great results, this is a must....
Anywho, my favorite macro setup as of late has been the Pentax M 50mm F/1.7 or Pentax M 28mm F/3.5 reversed on extension tubes. They give perfect magnification for insects....atleast the ones where I live. You would need a filter ring to K mount adapter for this. I would not suggest stacking lenses from your lineup. 50mm isn't long enough to stack, and using a zoom for this will give you results you'll likely not be happy with.
Note: Its almost pointless to attempt photographing insects with a reversed lens setup with extension tubes without a flash setup. Personally, simply reversing a 50mm or 28mm on the body does not give me nearly enough magnification and stacking with your lens lineup would be the same.
My two worthless cents.
06-29-2010, 01:11 AM   #17
TOUGEFC's Avatar
Yeah flash helps but its not pointless without it, all these are reversed stacked without flash, all natural light.
06-29-2010, 01:12 AM   #18
QuoteOriginally posted by excanonfd Quote
You have a Tamron Macro lens for Nikon - is it an auto-focus lens or manual focus? If it's the latter you can just exchange the Nikon mount with a Pentax PK/M or PK/A mount and enjoy partial or complete compatibility with Pentax DSLRs.
Thanks,
its the new autofocus lens
06-29-2010, 02:44 AM   #19
I thought that might be the case; but I am curious - are there any particularly advantageous reason for you to shoot macro using Pentax camera and lens with reversing rings and/or extension tubes, when you already have dedicated macro outfit of Tamron & nikon combination?
Thanks,
06-29-2010, 03:50 AM   #20
yes, i dont want to carry 2 bodies as my main body is my pentax camera
06-29-2010, 06:01 PM   #21
yeatzee's Avatar
QuoteOriginally posted by TOUGEFC Quote
Im sorry, what I meant was its almost pointless if you want any DOF.... Sometimes small DOF works, but more often than not it doesn't.
50mm, dont, k-mount, lens, macro, pentax lens, reverse, slr lens, stuff
Reverse Ring - Suitable lens? Flickeroo Pentax SLR Lens Discussion 4 06-20-2010 08:46 PM
what lenses are suitable for use with a reverse ring? Douglas_of_Sweden Pentax SLR Lens Discussion 17 06-25-2009 07:24 PM
Stargazer Lily - more M50 reverse ring macro mikeSF Post Your Photos! 15 05-21-2009 07:27 PM
Reverse Ring Macro mikeSF Post Your Photos! 4 03-01-2009 05:07 AM
All times are GMT -7. The time now is 11:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
