Oh, if only that red warning construction code wasn't there in that one shot... !
I too am so happy I purchased one recently.
If you can see the Milky Way where you live, you can take fantastic star shots with it. Try this, with -NO- stray light around... (else you get a color cast to the frame)
1) focus on manual, set to infinity
2) WB set to daylight
3) Shutter set to max (so unhappy its max is 30 seconds)
4) ISO set to 400
5) Shutter release set to IR (if you have the IR remote)
6) flash off (do I need to say that?
7) Lay the camera on its back, and prop it at an angle if the milky say isn't overhead (! if you're putting it on a rock, but cloth underneath ... else you'll scratch the screen like I did!
8) Use the IR remote to take the pic.
edit) duh, I forgot to include/mention the obvious, set aperture to f/1.4.
You can shoot multiples and stitch them together even. When you zoom in, you'll see the motion of all the stars within the 30 second timeframe; 1/8th of a degree. If you don't want the motion, reduce the shutter length.
