Originally posted by dgaies Correct, from what I've read there is more information contained in the FA version in terms of MTF information.
Neither the F nor FA 50/1.7 can take advantage of the in-body lens correction. That only works with DA lens (and FA limiteds via firmware update).
This is absolutely correct information.
My findings from use, are the F is easier to manual focus if one is doing so. Like an earlier poster said the F and FA are "spot on focus" when in AF mode.
One issue I have had with the FA was when I was pointing the lens downward to photograph a butterfly on the ground. The front element shifted and rendered the lens useless. It had to be sent back to Pentax for repair. Pentax replaced the lens with a brand new one.
It was rather disturbing to have a lens nearly fall apart when it was rather new out of the box. Has anyone else experienced anything like this? I am literally afraid to point this lens downward.
