06-29-2010, 05:13 AM   #1
Unusual Carl Zeiss M42 Lens
I acquired this lens sometime ago from a flea market as part of a job lot and since then it has just sat in a box unused until i rediscovered it a few days ago.
It is Marked Carl Zeiss Jena Nr. 3172780 Tessar 1:3.5 f=10.5cm T (the T is marked in red)
I have seen similar lenses to this on ebay, forums etc before but this copy has and odd lens barrel type extension. At first I thought is was just a homemade / custom extension tube as it just seems to create space between the lens and the camera body. However the lens does not appear to exceed the minimum focal distance (1.5m) marked on the focus ring, unless this has also been custom made. The barrel extension appears to be just held in place by two screws but removing these did not disconnect it, though it may just have become stuck with age and I am reluctant to force it.
Can anyone shed any light as to whether this is a standard lens design or a custom job? If it is a custom job would anyone like to speculate as to what purpose it may serve?
Any help much appreciated
(sorry for the shoddy pics, took them quick by the window light)
Fitted to my lovely MZ-S bought from this forum, shown purely for size comparison .
06-29-2010, 05:18 AM   #2
I've never seen/used this lens before but the barrel is almost certainly part of the original design. If you remove the barrel, it would not be a 105mm lens, not even close.
06-29-2010, 06:38 AM   #3
Asahiflex's Avatar
Your lens is almost 100% sure the standard lens from the postwar Primarflex, i.e. a Hasselblad-type camera. Do some googling and you'll find your lens mounted to a Primarflex
06-29-2010, 06:48 AM   #4
Thats what I thought originally but having seen what looks to be this lens without the extension piece I am unsure what to think.
A422) Tessar 3,5/10,5cm T Carl Zeiss Jena + Deckel ! on eBay (end time 26-Jul-10 18:17:42 BST)
Maybe it is a removable homemade adapter to change camera fitting. Having examined it more carefully now it looks as though the rear 'barrel extension' is less well made than the front portion, the edge of the barrel nearest the screw thread is slightly rougher.
06-29-2010, 06:50 AM   #5
QuoteOriginally posted by Asahiflex Quote
Cheers will do
06-29-2010, 07:43 AM   #6
Ben_Edict's Avatar
QuoteOriginally posted by Finchibabe Quote
The lens you linked to is also intended for use on a small viewcamera, quite like the Primaflex, Asahiflex shows in his image. So the extension was added to make the lens suitable for the much smaller 35mm format and allow infinity focus.
Ben
barrel, carl, custom, extension, job, k-mount, lens, light, pentax lens, slr lens, zeiss
Rare Carl Zeiss Jena STASI lens set for M42 Pentax mt. netuser Pentax SLR Lens Discussion 6 02-18-2010 06:07 PM
For Sale - Sold: Carl Zeiss Flektogon 35mm 2.4 M42 lkgroup Sold Items 1 12-09-2009 05:13 PM
Anyone have Carl Zeiss Jena Flektogon 35mm f/2.4 (M42) hinman Pentax SLR Lens Discussion 28 11-06-2009 08:41 AM
For Sale - Sold: Carl Zeiss Jena DDR 50mm f/2.8 M42 Lens, Excellent, only $50 shipped. wallyb Sold Items 1 03-11-2009 10:00 PM
For Sale - Sold: Carl Zeiss Jena DDR Flektogon 35mm f/2.4 Close-focusing M42 Lens wallyb Sold Items 6 02-11-2009 10:29 PM
All times are GMT -7. The time now is 04:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
