07-03-2010, 10:50 PM   #1
DA L 18-55mm kit lens... Sharpest aperture?
Anyone have any test results for sharpest aperture?
07-03-2010, 11:10 PM   #2
What value do you get when you set the "P" mode to MTF and read the value from the status line?
07-04-2010, 12:02 AM   #3
steve1307's Avatar
MTF line in P-mode should give you the sharpest apeture setting at any particular FL for a given scene. but apeture selected also depends on the available lighting obvoiusly.
Test data from Photozone.de and slrgear.com suggests f5.6(centre) or f8(centre&edges) at the short end and then f8 for the mid to long end. seems at 55mm edges are better at f11
Pentax SMC-DA 18-55mm f/3.5-5.6 AL - Review / Test Report - Analysis (AL I version i think?)
Pentax Lens: Zooms - Pentax 18-55mm f/3.5-5.6 AL II SMC DA (Tested) - SLRgear.com! (AL II version)
These are based 1 sample test.
07-04-2010, 12:03 AM   #4
i think it's 8-11, I keep it at 8 usually
07-04-2010, 12:51 AM   #5
26mm f/6.7
Practice is the criterion for assessing the quality
55mm/9.5
07-04-2010, 03:44 PM   #6
QuoteOriginally posted by steve1307 Quote
To be honest I've never heard of MTF before! I'll have to check it out some time. Until then, I'll just stick with f8
07-05-2010, 09:05 PM   #7
Canada_Rockies's Avatar
QuoteOriginally posted by maxwolfie Quote
I tend to use MTF when using program mode. It works with A series and later lenses, which leaves me with three where it works well. It is particularly impressive with the 50-135 - definitely sharp. It tends to keep the aperture right around f/4 - f/5.6, and is tack sharp.
07-06-2010, 12:09 AM   #8
QuoteOriginally posted by mikharPF Quote
26mm f/6.7
55mm/9.5
Wish I had my K200D when I was vising Kiev! Great shots
07-08-2013, 11:18 AM   #9
f9 works for me.
18-55mm kit, da l 18-55mm, k-mount, pentax lens, slr lens
How can I get the sharpest Pics possible with Kit Lenses? The Kurly One Troubleshooting and Beginner Help 9 03-12-2010 06:55 PM
k-x lens , kit 18-55mm f3.5-5.6 AL , what 50mm f1.4 can do over kit lens? crossing Troubleshooting and Beginner Help 19 01-15-2010 03:23 PM
DA 18-55mm AL II vs DAL 18-55mm (kit lens) vs DA 18-55mm WR rustynail925 Pentax SLR Lens Discussion 10 01-08-2010 02:06 PM
18-55mm WR compared to the original 18-55mm kit lens HogRider Pentax SLR Lens Discussion 19 11-26-2009 12:01 PM
All times are GMT -7. The time now is 11:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
