It looks like an M42 mount, so you will need to get an M42 to K mount adaptor
Also, it looks like an auto only lens, so you may need to force the aperture to stop down, by modifying the pin actuator.
I generally do this by taking the mount off the lens, and placing a spacer between the base of the mount and the lever the little pin pushes on, The perfect spacer is about 1/8 inch of refil tubing from a ball point pen.
there are threads on this mod, and it is removable if you want to resell the lens at some time.
Others have indicated that for $20 you can get an M42 mount that has a flange to activate this pin in the UK
