07-08-2010, 01:38 PM   #1
Reportage's Avatar
Ever had a lens needing more then +10 AF adjustment?
Extreme backfocusing.
Got a cheap day lens.
did a test and the odd thing was that what i aimed at was blur while the object next to it and slightly behind was tack sharp. Only at +10 was when the sharpness was on mostly on target. I am thinking +15 would do it.
Thing is the K20D doesnt have a debug mode but if its a software feature, maybe could email pentax to see if they can widen the AF adjustment range with next update.
07-08-2010, 02:18 PM   #2
imtheguy's Avatar
Yes there is a K20D debug mode to do adjustments beyond +/-10. I need to find the link to the directions for you and will post it back here if someone else does not beat me to it.
EDIT- Found it. http://www.andymcm.com/?p=22
Enjoy! It works. I use it.
07-12-2010, 09:10 PM   #3
heh, I'm at -10 for at least two lenses
With the K7 -- and I think I could use more adjustment. And even if that's optimal for those two lenses, what if I buy another lens tomorrow, and it needs way more than -10? I wish the scale had a broader spread, so that I could induce front focus and know I'd nailed it.
I've seen references to a debug hack for the K-7 also, but only for older firmware, not for version 1.03, so I don't dare try it. Also, wouldn't using it void the warranty?
07-13-2010, 12:07 AM   #4
I'm not sure if the scale of the K10D is the same.
One of my K10D bodies needs -19 for all lenses.
af, k-mount, lens, pentax lens, slr lens
Has anyone bumped up against the 20 lens limit for AF adjustment? G_Money Pentax DSLR Discussion 11 05-27-2010 06:59 PM
Lens Focus Adjustment and Pentax F 1.7x AF TC netuser Troubleshooting and Beginner Help 2 05-21-2010 07:25 AM
AF adjustment for third party lens? RTogog Pentax DSLR Discussion 10 03-10-2010 03:12 PM
Factory Adjustment of Lens to Body ? seacapt Pentax SLR Lens Discussion 16 11-12-2009 06:32 PM
Needing help with mystery lens mr tibbs Pentax SLR Lens Discussion 9 04-25-2009 02:07 AM
All times are GMT -7. The time now is 03:39 AM. | See also: NikonForums.com, part of our network of photo forums!
