07-09-2010, 04:55 AM   #1
Screwmount? Bayonet? K-mount? What is what?
I'm surfing eBay for _cheap_ lenses and I just don't understand the mounts. I know the new pentaxes are k mount. Is the k-mount equivalent to Screwmount? Or bayonet?
07-09-2010, 04:58 AM   #2
Asahiflex's Avatar
QuoteOriginally posted by Nimrad Quote
As the name implies, the screwmount has a screwmount (i.e. a screw-in thread). The k-mount is a bayonet mount with 3 tabs.
07-09-2010, 05:11 AM   #3
Hmm.. How can I spot the difference at eBay when people say "Pentax mount", "P/K Mount" "Pentax M Mount" etc?
For instance this one:
07-09-2010, 05:16 AM   #4
Asahiflex's Avatar
Well, that's a Pentax K-mount, so here you go
However, please note the long flange (for protecting the diaphragm lever). From the look of things this flange needs to be removed otherwise it cannot be mounted.
See Flange Fix for Vivitar Lenses - Mark Roberts Photography for more information.
As for your other mount questions; you should ask the seller if you aren't sure. Usually PK P/KA R-P/K Pentax-M means a K-mount lens, but the seller can easily come up with other fantasy names to make it more difficult for buyers.
07-09-2010, 05:26 AM   #5
Ira
Nim, when you come across any brand of lens that says M42, that will work with a Pentax that has the m42 to k adapter mounted on the body. M42 is a universal screw size.
07-09-2010, 05:35 AM   #6
Lowell Goudge's Avatar
a simple word of caution
the lens shown is a third party lens and the shield around the aperture activation lever is larger than necessary and will foul on the DSLR body internally.'
it needs to be trimmed, which is a simple operation, described in detail in the lens forum
07-09-2010, 05:51 AM   #7
Screwmount = any lens which you screw-in rather than latch-on. Typical sizes are M39 (early Pentax "Takumars") and M42 (later lenses, most of which resemble the M series).
K mount lenses are bayonet lenses and are very plentiful. There are many different series, but all of these lenses are compatible with Pentax DSLRs. Here's a page explaining the different series: Pentax K-Mount Lenses Explained
07-09-2010, 06:02 AM   #8
Asahiflex's Avatar
I need to correct you here, Adam. The early Asahiflex Takumars had a M37 screwmount. All other Takumars have the M42 screwmount. M39 is the Leica screwmount. Leica screwmount lenses can only be used as close-up/macro due to the different flange distance.
07-09-2010, 08:14 AM   #9
QuoteOriginally posted by Asahiflex Quote
There are also M39 Zenit (Russian) SLR lenses with the same registration as the M42.
On the K-mount end of things, there is also the Ricoh-P variant originally made to fit Ricoh cameras with program exposure modes. These have a pin that may jam into the AF drive on Pentax AF camera bodies.
To summarize Pentax/Asahi brand lenses (in historic order):
  • M37 Takumar screw (relatively rare)
  • M42 Takumar screw (common, may be adapted to fit all K-mount bodies)
  • Pentax-K, Pentax-M, Takumar Bayonet (all bayonet lenses lacking the "A" position on aperture ring...note that Takumar bayonet lenses were a bargain brand and are not worth much)
  • Pentax-AF (early AF lens, lacks "A" position)
  • Pentax-A, Takumar-A(have "A" position on aperture ring...see above note regarding non-screwmount Takumar lenses)
  • Pentax-F, Pentax-FA, Pentax-FAJ, Pentax-DA, Pentax-D FA (auto-focus lenses)
A comprehensive summary of all Pentax mount variants and the lenses that fit them (including a functionality matrix for cross-compatibility) may be found at:
http://kmp.bdimitrov.de/technology/summary/index.html
(Are we confused yet?)
Last edited by stevebrot; 07-09-2010 at 11:58 AM. Reason: Forgot Takumar-A on first try...Thank you to drougge for the heads up!!!
07-09-2010, 08:47 AM   #10
drougge's Avatar
  • Pentax-A, Takumar Bayonet (have "A" position on aperture ring...note that Takumar bayonet lenses were a bargain brand and are not worth much)
I think that's wrong, Takumar Bayonet doesn't have an A position, Takumar-A does. (At least for lenses I have seen.)
07-09-2010, 11:55 AM   #11
QuoteOriginally posted by drougge Quote
You are correct. I will edit my post...
(Tend to avoid even thinking about the K-mount Takumars...)
07-09-2010, 12:19 PM - 1 Like   #12
mickeyobe's Avatar
Pentax lens mounts
Nimrad,
We photographers should know that a picture is worth 1000 words.
See this for pictures.
SLR Lens Mount Identification Guide
There are more than just Pentax lenses here but I think all Pentax mounts are covered.
Mickey
07-09-2010, 01:13 PM   #13
as stevebot indicated, there are many different mounts both bayonet and screw mount, so caution is needed.
If, however, the use of the term bayonet or screw mount is used along with with pentax, then in general terms, you are discussing some form or K mount, or the M42 x 1 thread per mm Screw mount. (Yes I know the origonal asahiflex used an M37 thread, but those are rare)
Once you go outside of pentax mounts there are tons of non compatible bayonet or screw mounts. All current production SLRS (All makers) use bayonet mounts. Canon did make breach mount (the bayonet is on the camera not the lens) as did others but these are now obsolete
In screw mounts, you have the T mount which is M42 by .75 mm/ thread, the M39 mount, Miranda's M44 mount, and the list goes on and on.
ALso note that unless the lens is specifically made for pentax or other cameras with the 45.46mm regestry distance, you may or may not achieve infinity focus, even if you can get a thread adaptor.
bayonet, k-mount, pentax lens, screwmount, slr lens
Utilizing Old K mount and Bayonet Mount Lenses jk333 Pentax SLR Lens Discussion 11 08-15-2010 01:30 AM
nikon to pentax bayonet mount jdub Non-Pentax Cameras: Canon, Nikon, etc. 4 02-22-2010 01:42 PM
Screwmount vs. K-mount zoeybird Pentax SLR Lens Discussion 20 02-03-2009 02:20 AM
Takumar Bayonet 28mm f2.8 reverse mount wilkin Pentax SLR Lens Discussion 7 01-26-2009 02:17 AM
All times are GMT -7. The time now is 08:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
