07-10-2010, 09:14 PM   #1
kauaiguy's Avatar
diagonal out of focus lines w/ da*200 and *300 lenses?
Hi,
I have both the da*200 and da*300mm lenses, and both show strange diagonal lines in out of focus area. Is this just part of the design of the lenses, or do both have alignment problems? Anyone else notice this or have a solution? Seems kind of odd for expensive lenses.
only a UV filter on the lens, and removing it doesn't change the lines.
i did use the search function in the forums, but couldn't find any references.
thanks!
kauakguy
PENTAX K-7  Photo
07-10-2010, 09:50 PM   #2
imtheguy's Avatar
I think I see what you mean in the bokeh. No, can't say I ever noticed that kind of consistant strips using my da*300/4 EXCEPT some uglier bokeh like the last sample when I use a teleconverter. The bare lens has beautiful bokeh. I normally shoot at f5.6-8.
07-10-2010, 10:04 PM   #3
JohnBee's Avatar
I found such OOF effects with a combination of specific distances and arperture setting. It might take a bit of trial and error to learn which combinations cause this and how to avoid it. But this can occur with pretty much any lens.
07-11-2010, 01:34 AM   #4
Asahiflex's Avatar
This is certainly not good... You should know that the OOF circles have patterns in them of something that's directly in front of or inside the lens itself (for instance dust particles can be seen in the OOF circles). The OOF circles should be opaque without any diagonal lines.
Are you sure that removing the UV filter does not seem to cure this problem? I have a hard time believing that both lenses could be defective.
07-11-2010, 12:01 PM   #5
kauaiguy's Avatar
DA* 300mm oof lines
the 300mm is much worse, but i see lines in the 200mm also. those are horizontal and less sharp, but there. it's the 300 that really shows. removing the filter has no effect on the problem.
i guess i should go ahead and ship it off to service while the warranty's in effect.
07-11-2010, 01:29 PM   #6
Oh....no,i cant see anything like that.
And i use 3 different DA*300,one of these is my own.
Maybe the Filter?
da*200, focus, k-mount, lenses, lines, pentax lens, slr lens
For Sale - Sold: Diagonal Split Image Focus Screen Pentax K100D K200D DL spystyle Sold Items 2 08-29-2009 03:03 PM
Different lines on focus screen - what for? pbo Pentax Medium Format 2 07-12-2009 10:22 AM
For Sale - Sold: SG focus screen for MX/LX (grid lines) ryan s Sold Items 0 01-27-2009 07:26 PM
For Sale - Sold: Flash (AF360) and Lenses (FA50, DA50-200, Tam 28-300) jsundin Sold Items 8 09-03-2008 11:11 PM
crop lines on focus screen perstephone6 Pentax Camera and Field Accessories 8 08-30-2008 12:06 PM
All times are GMT -7. The time now is 03:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
