I have two of these - they've come for free or 'included with' some other lens - but mine are the T4's. Doesn't really matter for mounting on a K-x, but does make a difference when mounting on an ES-II or Nikon film camera
The thing I've done with my adapters - I use a thick rubber band (e.g. from supermarket bundled broccoli or asparagus) or a hair squngie around the stop-down mechanism on the mount, to make the lens act 'manual'.
Here's three different T4/Tx adapters I have (since then I've accumulated more)
The 'CS' one's the most useful when adapting to K mount as it has that push pin for stop down. The others have a sliding bit that doesn't stay slid.
The other way is to modify the mount to keep the pin in at all times - this should be easy and you can copy the way people modify adaptall-2 mounts.
The 90-230 is a good lens, especially at the wider end, with very nice color and bokeh.
