07-13-2010, 01:34 PM   #1
What tools do I need to disassemble lens?
What type of tools (specific screwdrivers) would I need to successfully disassemble lens? Could you recommend a place where I can order them? I already browsed through micro-tool website, but still unsure of what tools I need to purchase. thanks.
07-13-2010, 01:44 PM   #2
Moderator PEG Judges
Kerrowdown's Avatar
This is kinda scary zone stuff, I've always let folk who know what their about do this for me.
07-13-2010, 01:50 PM   #3
KxBlaze's Avatar
I disassembled a manual focus lens with just a micro flat and philips head screwdriver and tweezers, so I think a general set of micros will do.
Oh yeah, one more thing you will need are a set of balls of steel.
07-13-2010, 02:16 PM   #4
QuoteOriginally posted by ragamuffin1171 Quote
My tool set for lens/camera repair includes:
- An 18pc Precision UltraTech Screwdriver Set. The list price is $29, but it costs much less from Home Depot or a local hardware store.
- A dial caliper as spanner wrench. I have a 6" and a 4" version. These can also be used to remove the front lens ring. If you buy from Harborfreight, wait for a sale of the item, which happens every few weeks or so.
- A few tweezers of various kinds (pointed, slanted). Buy the best ones you can find.
- A piece of drawer liner similar to this. To loosen the front lens ring, I use a rear mount lens cap wrapped in the piece of drawer liner ("sticky surface" facing out). I push the whole thing on the ring and twist.
- A small can of naphtha (lighter fluid).
- A small can of denatured alcohol (available at the paint department of your local hardware store).
- Ziploc bags.
- A magnifier lamp.
- A small magnet.
07-13-2010, 02:25 PM   #5
SOldBear,
Thanks for your detailed list w/ links. I like your ingenuity on using dial caliper and drawer liner!
07-13-2010, 02:50 PM   #6
boriscleto's Avatar
A Vacuum pad opener instead of a spanner wrench
Vacuum Pad Camera Parts Opener, Japan Made!
or a full repair kit
Film Camera Maintenance & Repair Tool Set "C", Japan
07-13-2010, 04:48 PM   #7
I had asked the exact same question to Ralph Innes a while back, this was the detailed list he made for me:
Micro-Tools Product Search Results 3mm Moody blade
Micro-Tools Product Search Results 1 mm Moody blade
Micro-Tools Product Search Results Moody handle (for above)
Screwdriver Blade, JIS Type S #00 Moody #00 JIS blade
Screwdriver Blade, JIS Type S #000 Moody #000 JIS blade (optional)
Micro-Tools Product Search Results Scriber (I have a different one)
Micro-Tools Product Search Results NIWA #0 JIS driver
Micro-Tools Product Search Results NIWA #1 JIS driver
Micro-Tools Product Search Results NIWA handle (for above)
Screwdriver Blade, XPT 2.5mm X 50mm NIWA #2 JIS (optional)
07-13-2010, 04:52 PM   #8
gofour3's Avatar
I’d recommend practicing on a clunker or “parts” lens before you take on dissembling a A50/1.2 or some other high-end lens.
Phil.
07-13-2010, 09:10 PM   #9
Blue's Avatar
Hacksaw
Drill
Ball Peen Hammer
Vice
07-13-2010, 09:18 PM   #10
ducdao's Avatar
Hacksaw
Drill
Ball Peen Hammer
Vice
And a credit card to buy new lenses
07-13-2010, 09:26 PM   #11
Blue's Avatar
QuoteOriginally posted by ducdao Quote
I thought we were working on Canon lenses.
07-14-2010, 03:09 AM   #12
latex gloves, the unpowdered variant. change every 10 minutes, or when going to touch glass.
07-14-2010, 08:25 AM   #13
Tools
QuoteOriginally posted by SOldBear Quote
- Ziploc bags.
- A magnifier lamp.
- A small magnet.
SoldBear:
Thanks for the suggested list of tools. I never considered the dial caliper to remove the front lens ring.
07-14-2010, 08:49 AM   #14
Senior Moderator
Parallax's Avatar
In addition to the tools already listed, you need two bathtubs. Remove all of your clothes and get in one of them with the lens and all of your tools. Have someone place the other upside down over the top of you and tape the seams shut. This will make finding all of the pieces much easier after everything flies apart.
07-14-2010, 09:31 AM   #15
QuoteOriginally posted by boriscleto Quote
- Ziploc bags.
- A magnifier lamp.
- A small magnet.
Second the dial caliper suggestion. I've ground the inner measuring tips on mine to fit the slots on the lens rings. The outer measurement tips work great for large format lenses that have retaining rings holding them to the lens boards.
Also second the vacuum pad cork looking things. The work great for most lenses when removing the front element retaining ring. Be aware that they don't work for ALL lenses. I have a K135 f2.5 I'm trying to take apart right now that the tools don't quite fit.
k-mount, pentax lens, slr lens, tools
Disassemble the Pentax K10D maximm Pentax DSLR Discussion 8 10-23-2011 08:05 AM
How to disassemble the FA 28-70mm/F4 AL ? nanaky Pentax SLR Lens Discussion 6 05-25-2010 08:58 AM
What keys to disassemble?? Help pls bollicina31 Pentax SLR Lens Discussion 4 01-18-2010 12:33 PM
Need help to disassemble Pentax A 70-200mm lens manteiv Pentax SLR Lens Discussion 3 12-04-2009 02:18 PM
tough screw.. lens tools? milapse Pentax SLR Lens Discussion 5 10-04-2008 12:59 PM
All times are GMT -7. The time now is 03:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
