07-14-2010, 04:25 PM   #1
VIXIV's Avatar
Stick w/ Kit Lens or Rental??
I've been asked to take some snaps for a family party this weekend and am wondering if my kit lens will be suitable. I was thinking of renting a wide zoom like the 12-24 or Sigma 10-20, but CLR has both lenses rented out for the day I need. The 16-45 and 16-50 are both available (as I type), but...not sure if I shouldn't just stick with my kit lens...
...Yea? ...Nay? Input appreciated
07-14-2010, 04:33 PM   #2
mtroute's Avatar
I have the Kit and the 10-20mm, frankly as much as I like the 10-20 it is a bit wide (at 10mm there is a fair amount of distortion) and more importantly slow for interior shots without flash. I would probably stick with the kit as it has less distortion and is a bit more versatile in my opinion.
If you are comfortable with flash (external is best) the onboard using TV mode and running around 1/30-1/15 can get you some nice shot with either lens.
07-14-2010, 04:58 PM   #3
Unless you plan on making large prints, you should be fine with the kit lens. Although if you're going to be taking a lot of portraits, I would think you would need something tighter rather than wider.
07-14-2010, 05:31 PM   #4
VIXIV's Avatar
I stopped by the location and asked how things were going to be set up. I was considering the wider zooms in case things got too tight and I wouldn't be able to take a few steps back, but I do suppose 18mm will be wide enough.
I suppose a setup a the 18-55, FA 35 and 50, plus EF500 Super will be all, it not more than I really need after all. Any excuse to play with different toys gets the imagination going, I guess
07-14-2010, 09:45 PM   #5
KxBlaze's Avatar
I don't think you will need anything wider than 18mm. You kit lens will do just fine and you can save some $ by not renting.
Hey with the $ you save maybe you can buy a new lens. Haha
07-14-2010, 09:47 PM   #6
SpecialK's Avatar
I think you can get by with just the 18-55, flash, and maybe a tripod.
07-14-2010, 10:00 PM   #7
VIXIV's Avatar
QuoteOriginally posted by KxBlaze Quote
Well, that was part of my logic in favor of renting: try before I buy!
I've been taking some feeler shots w/ the kit lens @ 18-35, and it'll do well enough.
k-mount, kit, lens, pentax lens, slr lens, w/ kit lens
Lens Rental Review Jesus Pentax SLR Lens Discussion 6 06-20-2009 01:03 PM
Lens rental BigT Pentax SLR Lens Discussion 1 09-14-2008 08:48 AM
Camera Lens Rental KFrog Pentax SLR Lens Discussion 2 04-25-2008 06:28 PM
Lens rental?? jshurak Pentax DSLR Discussion 3 03-02-2008 04:34 AM
Stick with the kit lens or go for the prime? lastdodobird Pentax SLR Lens Discussion 24 11-19-2007 12:07 AM
All times are GMT -7. The time now is 12:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
