Originally posted by wlachan Any prime shooters know that one cannot fill every gap, and the gap between 50 & 70 is really small. In fact, I feel my 43 & 77 are too close in practice.
As a prime shooter primarily, my "gap" is between 40 and 70, and I feel constrained by it at all. Although when I was primarily a zoom shooter, I *did* feel a big difference going from 18-55 + 70-300 to 18-55 + 50-200. It actually wasn't that I shot in the 50-70 range all that much - it was that by having 50mm available on my telephoto zoom, I felt I could get away with leaving the 50-200 on the camera in situations where I'd otherwise have switched to the 18-55 if I had the 70-300 mounted. Of course, I also simply didn't like the size, weight, focus speed, or lack of quick shift on the 70-300, so I was always in hurry to get it off the camera anyhow. And that's not going to be so relevant for you. But the bottom line was, by having a 50-200 rather than 70-300, I change lenses less.
However, given you're not going to get a 50-200 to replace your 70-200 (I assume that's an f/2.8), buying a lens to plug the gap is not going to reduce lenses changes, and like I said, it's not like I actually shot in that range much. With the 50-200, I tend shoot a lot right at 50, and then basically skip right to the upper 60's or so.
