Originally posted by trishytee I have been doing some successful portraits with strobes, and would now like to try a natural light pic of a mother and baby. Trouble is the only lens that lets me stop down to 2.8 or 4.00 is my ancient prime lens, which means I will be just about sitting on their heads. I have tried using 5.6 @ 125 with my 70 to 300 lens but the moment I zoom in I lose the setting. I have tried with the shorter 70ml lens but again if I zoom in I lose the apertature. I tried (all this with toys at moment)using the available winddow light, then bringing in the soft box (umbrella) and putting a continuous light on the object and an ISO of 800 but that was still too dark. Sooo any idea on what lens I should be looking for, or should I invest in one of those continuous light setups?
My strobes are pretty ancient and only have high and low settings. I don't want to use them as strobes for this shot unless I really have to.
cheers Trish
The "fast" portrait lenses I use/have used:
DA 70ltd/2.4 - Not that fast, but sooo smal, and a great street-portrait lens.
DA*50-135/2.8 - Good choise for a portrait zoom. One of my first threads on this forum in 2008 was a shoot out between this zoom and four A and A* primes. Conclusion was that while not so good at 135 (and 50) mm, it approach a prime in quality in the middle.
A*85/1.4 - Great portrait lens, from f1.8 it is really good, but a bit soft at f1.4. For that reason you may as well buy the FA77ltd/1.8 which is the same optical solution, but Pentax desided to drop the f1.4 and get a more compact lens since the extra stop wasn't that usefull anyway.
"K" 105/2.8 - Like this a lot, much better than the 100/2.8, renders faces like the K85/1.8, but for a smaller cost.
A100/2.8 (same as M100/2.8 optically) - not as good as the 105mm, but good enough to be my only portrait lens in the 80's until I got my first 85mm.
Super-Takumar 100/2.8 (non SMC version) - like this a lot, behaves a bit like the K105, but not as sharp.
DFA100/2.8 macro - good for portraits as well as for macro, sharp as all macro's, but when it goes hunting it goes a long way because of its close focus capacity which can be annoying. (Almost) identical optics to the F/FA versions but lighter and smaller filter. The new WR version with its rounded apperture blades should be interresting for portraits, but I haven't had a chance to try one.
A*135/1.8 - Great lens, truly great. Sharp from 1.8. I know it is a bit long for portraits on APS-C, but on film it works.
The other Pentax K-mount 135mm's goes like K135/2.5, fine and sharp, M135/3.5 compact, sharp enough, smother skin, K135/3.5, not that good.
On APS-C I coun't also 50mm as portrait lenses.
A50/1.7 (same optically as the other 50/1.7 lenses from Pentax) - fine portrait lenses, sharp from f2, the M50/1.7 is probably the best ratio between quality and cost that you can get for a Pentax 50mm.
FA50/1.4 (same optically as A and F50/1.4) - fine portrait lens, a little bluish color rending, which is unusual for Pentax
"K"55/1.8 or f2 (same optics), also same as SMC Takumar 55/1.8 or 2 - I like these for portrait, a little less sharp than the f1.7 and f1.4 but that may work well for portaits and a bit warmer color
Super-Takumar 50/1.4 - nice lens that works for portraits, but I actually prefere the 55 or 105 takumars
Some 3rd party
Tamron adaptal 2 SP 90mm f2.5 macro - good portrait lens as well as macro, available for good prices, but if you wan't A connection remember to include a KA adaptal adapter in the cost, it goes for much more than the K adapter.
Mamiya 85/2.8 (m42) - rare and small, not that fast, but works nice on portraits...but you can't mount it on a K mount camera without some modification.
I have too many other 3rd party 50 and 135mm lenses to even start writing about, some good some bad, but most so cheap that they are worth trying, and all fast compared to todays consumer zooms.
As for Pentax portrait lenses I don't own/haven't used enough to have a really well founded opinion about. Other's on the forum know the m42 85mm's well, but from what I have seen I suspect that the 85/1.9 Super Tak is better than it's reputation. Same applies to the M85/2, which is also amazingly small.
FA*85/1.4 and DA*55/1.4 you need to ask someone else about.
Edit: most shots in my flickr are sorted in folders according to lens if you want examples.
