11-29-2006, 05:06 PM   #1
Duh_Vinci's Avatar
Aperture ring on lenses for Pentax?
Hello,
Sorry in advance for the dumb question, but since I transitioned into DSLR with Canon (my Pentax arrives tomorrow), I never had to deal aperture ring of the lens - Aperture is controlled at the camera body, none of my lenses for Canon have it...
For example, an AF lens with the aperture ring, and "A" position - that is where the lens would stay for most of the shooting modes and aperture would be controlled via the camera adjustments?
Then for example again, if I was to use an extention tubes for "extreme budget" macro photography (and this would make a lens all manual), I can then move the aperture ring of the lens from "A" position to desired aperture setting to achieve the DOF? And the camera (depending on the mode, Av for example) would select the appropriate shutter speed? Or if in manual mode "M", again, I would set the aperture on the lens ring to where I want it to be and adjust shutter speed according to the meter in the camera?
Thanks in advance for your help!
Regards,
D
11-29-2006, 05:14 PM   #2
if you leave it in A, it operates just like the DA lenses, or your EOS lenses without a ring. Camera handles all the aperature adjustments.
If you use extension tubes - depending on which kind you have:
If it carries the aperature lever thru, you can set your aperature, focus, meter with a button on the camera, then shoot.
If it doesn't carry the aperature lever, then you need to set the aperature and meter, then open it back up to focus (or vise versa - what ever works I guess) -
I'm pretty sure this is how it works.
11-29-2006, 07:32 PM   #3
*isteve's Avatar
Most Pentax lenses these days (FA J and later DA lenses) have no aperture ring. The rest can indeed be left in A mode and controlled from the dials just like canon.
11-29-2006, 09:13 PM   #4
roentarre's Avatar
My two limited lenses have aperture ring and i love them. It is the addictive feel when I move the ring - feeling so solid and i am adjusting something... Improving my dexterity i guess
I made a mistake not knowing this when i first used the lens - all shots are taken wide open at f1.8.... I learnt from mistakes
11-30-2006, 12:42 PM   #5
Duh_Vinci's Avatar
Good info guys, thank you very much for your help! Camera is here, charging, will try in few hours to see how this aperture ring works...
Regards,
D
12-06-2006, 09:24 PM   #6
Aperature
Ha, I didn't know until I recently bought a DA lens that some did not have aperature rings.
advance, aperture, camera, canon, k-mount, lens, lenses, mode, pentax lens, position, shutter, slr lens
Pentax-A 50mm f1.7 Aperture ring repair Just1MoreDave Maintenance and Repair Articles 53 10-22-2016 11:42 AM
Using the Aperture Ring on Auto Focus Lenses agsy Pentax DSLR Discussion 9 10-12-2010 10:51 AM
DA lenses and what ever happened with the aperture ring? Toro Pentax SLR Lens Discussion 9 04-18-2010 06:49 PM
MZ-S and aperture-ring less lenses Gooshin Pentax Film SLR Discussion 10 01-11-2009 12:28 PM
Aperture ring on FA lenses ankit Pentax DSLR Discussion 8 02-04-2008 04:54 AM
All times are GMT -7. The time now is 02:44 PM. | See also: NikonForums.com, part of our network of photo forums!
