07-29-2010, 08:27 AM   #1
Adaptall 2 mount help please
Can I mount an adaptall 2 lens with M42 mount onto my K-x with its Pentax M42 to K mount adptor fitted? And how would the lens work? The lens is a 28mm 2.5.
Or do I need a PK or PKA adaptor? The PK mount is cheap on ebay, but the PKA seems rare and expensive but will enable more functions ( me a begginer more functions is good ).
Also are there any issues with the cheap ebay mounts as there are with the M42 to k ones?
Thanks
07-29-2010, 09:01 AM - 1 Like   #2
Nesster's Avatar
1) yes, you can mount a M42 Adaptall via the K adapter. The M42 adaptalls however lack an a/m switch so you'll be limited to open aperture only, unless you modify the adaptall to hold the pin in.
2) Either a K or KA adaptall work, the K works like a M lens - manual stop down metering but auto aperture - and the KA works like an A lens - supports the auto exposure modes.
07-29-2010, 09:13 AM   #3
Thanks Nesster, don't think I'll be modifying anything , but at least I know I can put it on my camera for a play to see if I want to spend $ on an adaptor.
07-29-2010, 10:38 AM   #4
What Nesster said...
The cost of an Adaptall-2 M42 + M42/K adapter would be more than just getting the standard Adaptall-2 P/K and would offer no real advantage in terms of usability. According to your profile, you shoot with a K-x. On that camera, your best meter accuracy is in M-mode, so the a K-mount is an advantage over M42.
adaptall, ebay, functions, k-mount, lens, m42, pentax lens, pk, pka, slr lens
Adaptall 1 lens with Adaptall 2 to EOS mount Squier Pentax SLR Lens Discussion 0 08-04-2009 01:35 PM
Adaptall Ka mount MattGunn Pentax SLR Lens Discussion 7 06-28-2009 10:15 AM
Adaptall 2 mount asfinn59 Pentax SLR Lens Discussion 11 03-24-2008 10:51 AM
Will an Adaptall-one k-mount adapter work on an Adaptall-TWO lens? Grimlock Pentax SLR Lens Discussion 1 02-07-2008 04:18 PM
All times are GMT -7. The time now is 04:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
