07-30-2010, 03:59 PM   #1
guillermovilas's Avatar
60-250mm f/4 does zoom out
I thought that the term 'IF' ment internal focus therefore the lens wouldn't extend zooming out but i see that this is still the case with this Pentax 60-250mm f/4
Why is it so ?
07-30-2010, 04:07 PM   #2
Jodokast96's Avatar
Focus is not the same as zoom.
07-30-2010, 04:09 PM   #3
QuoteOriginally posted by Jodokast96 Quote
Whats the term for internal zoom then ?
07-30-2010, 04:18 PM   #4
The 60-250 is not an internal zoom. The only one that IS is the 50-135 (in the SDM DA* line). Internal focus means the front element (for all practical purposes) won't rotate when the lens is focused. That becomes important when you are using something like a polarizer or a graduated filter (such as an ND).
07-30-2010, 04:49 PM   #5
Clinton's Avatar
QuoteOriginally posted by JeffJS Quote
It also means that air isn't being pulled into and pushed out of the lens, and that dust and moisture in the front wont be distributed inside the lens when retracted.
Neither of these should be an issue with a weather/dust sealed lens. I've not heard of any issues with people having dust inside their 60-250.
07-30-2010, 08:12 PM   #6
scorpioh's Avatar
Not quite true. None of my non-internal focus lenses have rotating front element.
07-30-2010, 08:16 PM   #7
QuoteOriginally posted by scorpioh Quote
So what does that have to do with the subject of internal focus and internal zoom? IOW, What did I say that is not quite true? The front of my Tamron 70-300 both extends and rotates when focused. A Non IF lens.
07-30-2010, 08:25 PM - 1 Like   #8
Jodokast96's Avatar
An IF lens will not extend or rotate when focusing. A non-IF lens will extend, but may or may not rotate.
07-31-2010, 12:08 PM   #9
exactly,internal focus is not equivalent with internal zoom.
60-250mm, f/4, k-mount, pentax lens, slr lens
Which Zoom Lens? "Tamron AF 18-250mm", "Pentax-DA 18-250mm" or "Sigma 18-250mm" hoomanshb Pentax SLR Lens Discussion 4 07-30-2010 09:50 AM
Tamron 18-250mm zoom on ist.DL nichevo Pentax SLR Lens Discussion 2 05-31-2010 12:11 PM
K-7 and the Pentax 18-250mm zoom AlexM Pentax DSLR Discussion 10 07-25-2009 10:09 PM
Pentax digital 18 - 250mm zoom dougiewill Pentax SLR Lens Discussion 7 01-14-2009 04:08 AM
Pentax DA 18-250mm Zoom Lens Hood shutterbob Pentax SLR Lens Discussion 3 12-18-2007 11:26 AM
All times are GMT -7. The time now is 02:20 AM. | See also: NikonForums.com, part of our network of photo forums!
