08-01-2010, 07:24 AM   #16
Nubi
Guest
QuoteOriginally posted by Asahiflex Quote
Damn, even though I already have the magnificent FA* 85/1.4 [IF], my LBA is acting up big time after seeing those product shots and sample photos. One day I will have one too (or so I hope)
I am a bit curious that someone like yourself who already owns FA*85, what would you gain by getting an A*, other than you know, LBA gratification??? Aren't they supposed to be of similar optical formula?
I do think that owning FA*85 and A*85 at the same time is rather attractive . . . . .
08-01-2010, 07:28 AM   #17
Asahiflex's Avatar
QuoteOriginally posted by Nubi Quote
They are not really the same; the A* 85 shares its optical layout with the FA77 Limited. The A* is said to be sharper than the FA* and better suited for allround photography, whereas the FA* is really optimized for portrait distances.
However, I have used the A* in the past (for a few weeks) and found it prone to CA in difficult conditions (but sharp it is). The FA* does not exhibit the same "problem". (BTW: the A* 135/1.8 is even worse in this regard).
08-01-2010, 09:43 AM   #18
Humm... I own the FA*85, it is really an excellent lens but it is also very prone to purple fringing; all these very fast lenses exhibit the same flaw; to complement it I have simply bought the DA70 limited
08-01-2010, 09:50 AM   #19
Asahiflex's Avatar
QuoteOriginally posted by goubejp Quote
True; but the FA* does not show PF nearly as often as the A*. The A* even showed PF stopped down to f/5.6. I have used the FA* in numerous situations (even wide open) and I never saw any bad PF. However, the FA* tends to blow highlights easily, but that's about the only complaint I have. The FA* 85/1.4 at f/1.4 is sharper than the FA 50 at f/1.4 (I tried two copies of the FA50).
08-01-2010, 11:15 AM   #20
axl
axl's Avatar
@ Asahiflex:
how does 77ltd compare to those 85s?
thanks
Peter
08-01-2010, 11:31 AM   #21
Look what you have done, Sailor:
Pentaxor, that should not be a problem. Fifth floor is great. Better forth or sixth . . . Let's do this. You and me. I am thinking maybe smc might want to join us . . . . . Maybe three of us. Every four month we will play with A* 85. Yes. What a deal.
Nubi, didn't we follow the end of your LBA?
QuoteOriginally posted by axl Quote
@ Asahiflex:
thanks
Peter
Peter, are the 12 months passed yet?
Just kidding, of course
08-01-2010, 11:39 AM   #22
Nubi
Guest
Ah, yes. We did. I already slipped once off the wagon . . . . Bought a 28/3.5 shift for ~$500. But you see, A* 85 is an exception (among many).
QuoteOriginally posted by Bart Quote
08-01-2010, 11:41 AM   #23
Asahiflex's Avatar
@ Asahiflex:
thanks
Peter
Well, the output of the 77ltd looks very similar to the A* 85. But the FA* has the typical FA* rendering (hard to explain; you have to see it). Of all of these I like the FA* the most, but that's hardly a surprise.
08-01-2010, 11:44 AM   #24
Sailor's Avatar
Look what you have done, Sailor . . . . . . . .
I'm shameless .
Jer
08-02-2010, 12:16 AM   #25
axl
axl's Avatar
lol...
not quite yet
I'm asking out of interest
08-02-2010, 03:52 AM   #26
rparmar's Avatar
There have been many posts about this over the years, which I have followed intently. The best of these had side-by-side shots, which have unfortunately now evaporated into the digital ether. My information is second-hand, but comes from the best sources.
The FA*85 is specifically designed for portraits and so is optimised for that distance and a very particular focus. Basically, it front focuses so the subject is nearer to the back of the depth of field. This means that lovely bokeh begins directly behind the subject. The necessary by-product is that sharpness is sacrificed. This is known to all who have compared with the A*85, a sharper lens at the large apertures it would likely be used at (up until at least f/4, some say f/8).
The FA*85 has an 8 element in 7 group optical formula while the A*85 and FA77 have an almost identical 7 element in 6 group construction. They are also two of the few Fixed Rear Element Extension (FREE) focusing lenses Pentax has made. But the FA77 is half the size, half the weight, more convenient and looks better too (IMO). Some even prefer the bokeh. Certainly in this regard there is little to choose between them. All of this has been achieved by sacrificing two-thirds of a stop, a most admirable compromise, since few would use f/1.4 in practical use.
FA77 also has better control of aberrations. And is a better field of view on crop sensor, IMO, being similar to 120mm FF. (Note that the lens is closer to an actual 80mm than what it is rated at.)
08-02-2010, 05:04 AM   #27
Here is an example - very extreme, I must confess, and I have not set the proper settings for the lens - it is stopped down at f2.8 as it was have been possible to stop down at f5.6 for this completely static subject;
this is a 100 % crop so it is far less visible on the original shot; but ths issue is here; I don't have a A*85 to compare though.
Note that the clarity of the image and the excellent rendering on the stones anyway Regards
08-02-2010, 05:13 AM   #28
If you understand french... look here :
Test_85mm
It compares Pentax A*85, FA*85, FA77, DA*50-135, Zeiss 85 and Samyang 85
08-02-2010, 05:32 AM   #29
TOUGEFC's Avatar
Test_85mm
Here it is translated to english
Translation result for http://monuniverspentax.com/test_85mm_pentax.html
08-02-2010, 06:17 AM   #30
Asahiflex's Avatar
Thanks for posting the link again! I knew that shootout, but I never paid much attention to it. It seems that I don't like the Zeiss and that I made a cood choice with my FA*
guy, k-mount, pentax a*, pentax lens, slr lens
NEW Pentax 85mm/1.2 vindrum Pentax SLR Lens Discussion 14 12-18-2016 11:33 PM
Rumored SAMSUNG 85mm 1.4 could be a 85mm FA rebrand omega leader Pentax News and Rumors 19 09-07-2009 03:05 PM
All times are GMT -7. The time now is 09:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
