08-05-2010, 06:50 AM   #16
ivoire's Avatar
I can't comment on you comparison question as I've no experience. As for the zoom, if you really want that kind of flexibility, consider the Sigma 100-300mm and a 1.4xtc
09-18-2010, 07:10 PM   #17
I just wanted to update you on my decision.
I ended up with a DA* 300mm f/4 that I grabbed from the marketplace.
I was really looking for better AF and IQ since I was coming from a Tamron 70-300. I didn't want to compromise with the 150-500 or 100-300. The DA* 300 is also smaller than the big zoom options and is very hand holdable. The 300mm will also take a TC more readily and will give me equivalent reach of a big zoom with better quality in a smaller package.
SDM is absolutely fantastic as this is my first lens that has it. Now I just need a quiet shutter to match it.
Oddly, it seems I've got a good bit of back focus with the 300mm f/4, but adding +110 seems to have fixed it up.
I've also added a battery grip which makes using the lens much nicer (and really it adds to the camera's handling with any lens). I also picked up a Sun Sniper strap since a K10D + grip + 300mm gets pretty heavy around the neck. It makes the camera seem relatively weightless now!
Here are a few samples from this past week:
Komodo Dragon:
Mandrill:
Gold Finch:
09-18-2010, 08:57 PM   #18
8540tomg's Avatar
To extend the manual focus long telephoto suggestions above you might consider the SMC Pentax M 400/5.6.
It has some issues with CA/PF in certain conditions but can be had for far less than a DA* 300/4.
Great shots Dominique. You put that DA* 300/4 to good use. By way of comparison here's a few Waxwing shots from the M 400/5.6.
It takes some getting used to but I like it.
Tom G
09-19-2010, 08:11 AM   #19
Here is a Cardinal taken with the Bigma (Non HSM or OS). I find that if I use a tripod and remote release, I can get very sharp results with it most of the time, even at 500mm.
BIF pictures are harder to achieve at 500mm, at least for me. I shoot most of those at 3-350mm then crop if needed.
09-19-2010, 08:23 AM   #20
ivoire's Avatar
QuoteOriginally posted by GaryH Quote
BIF pictures are harder to achieve at 500mm, at least for me. I shoot most of those at 3-350mm then crop if needed.Attachment 71051
Nice work with the Bigma. I'm leaning toward getting one for wildlife and its convenience.
09-20-2010, 06:04 AM   #21
QuoteOriginally posted by ivoire Quote
I think you will like it. Once you get over the size and weight you will learn get the best out of it. It has been my most used lens since I got it. Now I am shopping for a new ballhead since the Manfrotto I have creeps every time I tighten the ball.
300mm, da*, k-mount, lens, os, pentax, pentax lens, questions, sigma, slr lens, tamron, tc
55-300mm vs. 70-300mm: Need Advice... InfinitySL Pentax SLR Lens Discussion 13 05-10-2010 08:18 PM
Lens advice re: Sigma 28-300mm F3.5-6.3 DG allill Pentax DSLR Discussion 8 12-03-2008 07:54 AM
Need advice on my second lens pentaxpaul Pentax SLR Lens Discussion 21 12-02-2008 09:19 AM
sigma 70-300mm advice plse trumpyman Pentax SLR Lens Discussion 3 09-08-2007 05:11 AM
Your Advice Pl-Opportunity to buy a Sigma 28-300mm DL lens tasha_22 Pentax SLR Lens Discussion 9 05-05-2007 06:51 AM
All times are GMT -7. The time now is 12:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
