08-09-2010, 08:08 AM   #1
Problem with new old Mamiya 135mm 2.8
My $10 bargain arrived today, and she won't tighten all the way into the M42 adapter.
Anybody got a clue?
She's labeled Auto Mamiya Sekor SX, but without an M/A switch, I was certain this had to be native M42.
08-09-2010, 08:46 AM   #2
boriscleto's Avatar
The Mamiya Sekor SX lenses had an extra pin to transmit aperture data to the camera. Could that be what is causing the problem?
08-09-2010, 08:48 AM   #3
boriscleto's Avatar
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/50524-why-no-l...iya-sekor.html
08-09-2010, 08:59 AM   #4
Ira
QuoteOriginally posted by boriscleto Quote
There is indeed a tiny little pin protruding on the outer edge perimeter of the base, but there's also a little lip around there too, maybe 1/32" high, and the pin doesn't extend beyond that.
I'll check your link--and thanks!
08-09-2010, 09:09 AM   #5
Ira
This seems to be my answer, on page two your link:
"BTW I just realised how much work it is to have converted that SX lens. Rip out that little pin (or grind it down), take apart the back and grind down the outer aperture ring (cause it is protruding, don't fit on K100D otherwise), and also lock the mechanics to 'manual', cause it doesn't have an A/M switch. Now the aperture clicks are a little heavy to move, due to the 'manual' conversion."
But how the heck do you lock the mechanics?
This lens is weird:
It has a retractable lens hood, and the lens is two pieces which actually screw apart! And an older model--only 5 digits in serial #.
k-mount, m42, mamiya, pentax lens, slr lens
problem with mamiya/sekor on spottie F? ragamuffin1171 Pentax SLR Lens Discussion 4 05-24-2010 04:10 PM
Anyone else have this DA* 50-135mm problem? PentaxPoke Pentax SLR Lens Discussion 104 03-30-2010 01:31 AM
DA*50-135mm f2.8 SDM Problems / No Problem rustynail925 Pentax SLR Lens Discussion 30 03-22-2010 06:08 PM
Problem with the 50-135mm DA* offertonhatter Pentax SLR Lens Discussion 15 03-01-2009 09:53 PM
For Sale - Sold: Pentax DA* 50-135mm f/2.8, M 40mm f/2.8, Mamiya 50mm f/2.0, Geunine M42 adapte hinman Sold Items 19 12-19-2008 11:07 AM
All times are GMT -7. The time now is 01:21 PM. | See also: NikonForums.com, part of our network of photo forums!
