08-09-2010, 09:51 PM   #1
ManhattanProject's Avatar
Ghosting - Due to UV?
Hey all, I recently took some shots that had some very apparent ghosting and I was wondering what might cause it. My first thought was that it could be the UVF, but not every shot I took did it so I couldn't just remove the UVF and necessarily draw a conclusion based on the results. Just looking for some friendly advice/insight, thanks!
DA* 50-135mm + Hoya Super HMC Pro 1
08-09-2010, 11:26 PM   #2
This is internal reflections from air glass interfaces inside the lens, off the sensor, or possibly off the surfaces of the filter.
Try repeating the photo without the filter on the front.
Regards
Chris Stone
08-10-2010, 04:13 PM   #3
RioRico's Avatar
If you use certain forensic Sigma and Fuji dSLRs, or shoot film, you can worry about UV. Otherwise not -- UV is filtered out by layers atop the sensor. As Chris said, you're most likely getting reflections off the filter.
08-10-2010, 04:15 PM   #4
Blue's Avatar
Was there moisture or mist around those lights?
08-10-2010, 07:29 PM   #5
Wheatfield's Avatar
You can be quite certain that is off your filter.
The reason for why it isn't on every picture is because there are very few absolutes in this world, and what you are seeing isn't one of the few.
08-11-2010, 03:00 PM   #6
Thank you for the responses. I'm hoping, as it seems, that its the uvf and not my glass.
k-mount, pentax lens, slr lens
SMC A 35 - 105mm 3.5 and ghosting on digital c a sugg Pentax SLR Lens Discussion 11 04-15-2010 12:05 AM
K-x: ghosting in image pentaxpup Pentax DSLR Discussion 10 12-14-2009 05:26 AM
weird ghosting and very bright poppinfizz Troubleshooting and Beginner Help 18 07-09-2009 05:05 AM
K200D deserves more attention! A couple of questions (ghosting and rectilinear uw) cheekygeek Pentax DSLR Discussion 3 07-14-2008 06:30 AM
Filter ghosting? I GOT PROOF! rburgoss Photographic Technique 31 06-23-2008 02:02 PM
All times are GMT -7. The time now is 06:15 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
