08-10-2010, 09:07 AM   #1
Xlusionist's Avatar
Lens operating temperature
Hi guys,
I'm using K-x and its operating temperature ranges from 32 F to 104 F. Does this operating temperature applies to the lenses?
I have 18-55mm and 50-200mm, both DA L which are plastic mount. Are they less tolerant to heat?
08-10-2010, 11:34 AM   #2
I doubt anything is going to happen to your lenses if you exceed these temperatures, but I wouldn't recommend extended exposure (especially to heat).
08-10-2010, 12:04 PM   #3
bdery's Avatar
Every materials, including plastic, glass and metal, will alter its shape with temperature. One of the rare exceptions is Invar, a type of steel (roughly speaking) that is almost invariant (hence the name).
At "room temperatures" your lenses will be fine, the deformations are small. I've often used my lenses in the cold snow without trouble. I believe to permanently damage a lens, you would have to expose it to a temperature that your body cannot support.
08-10-2010, 01:07 PM   #4
The main issue with lenses and temperature are condensation on internal elements when going from warm humid to cold (may leave water marks) and migration of lubrication when hot. When very cold, AF and aperture stopdown may be affected with potential for jamming and/or slow response. Thermal expansion (noted above) is another potential issue.
08-10-2010, 07:01 PM   #5
Xlusionist's Avatar
thanks guys. i raised this concern because of the frequent unbearable heat i'm facing doing outdoor shots.
Am i right to say that high temperature does more "damages" than low temperature?
08-10-2010, 07:17 PM   #6
QuoteOriginally posted by Xlusionist Quote
High temps have the potential to warp components of the lens if exposed for long periods of time (hours) - especially if they are in direct sunlight.
One good point made earlier was about the lens fogging when moving between extremes. That's something to watch for carefully. It always happens when you need it most and can be simply avoided by staying away from extremes (i.e. don't take your camera from a 80 degree car to a 12 degree outside. It's easier to leave them in the trunk while traveling. That still protects the equipment, but drops the temperature variance significantly.
k-mount, pentax lens, slr lens, temperature
Camera Operating temperature? D4rknezz Pentax DSLR Discussion 5 10-21-2009 07:36 AM
k200D operating noise wizandrzej Pentax DSLR Discussion 1 06-02-2009 08:40 PM
For Sale - Sold: *FREE* PZ-1p Operating Manual PrimeObjectif Sold Items 3 06-01-2009 08:34 PM
Operating Temperature brett Pentax DSLR Discussion 21 01-29-2007 07:59 PM
All times are GMT -7. The time now is 10:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
