Originally posted by dude163 re: Minolta Nikkor, how does that fir onto a Pentax Body, do you need an adapter?
More than a few threads here deal with mounting Minolta and Nikkor to Pentax. Yes, inferior optical adapters exist, which tend to ruin whatever was special about the lens. An adapter is hardly worth the cost, unless the lens is VERY special.
Both Minoltas and Nikkors can be modified for a PK mount. Adapting a Minolta MC-MD mount requires major surgery; it's a non-trivial operation. I don't know if Minolta AF (Maxxum) lenses can be adapted. You could try a little googling, eh?
Adapting non-AF Nikkors is pretty easy -- I just finished-off my third modification an hour ago (and I'm no mechanic). I may mod a fourth lens tomorrow. Many Nikkors can just be press-fit onto a Pentax mount. With press-fitting or my simple mod, the Nikkors are totally manual, which makes metering simple. With my mod, they can also be used with Catch-In-Focus. AF Nikkors can probably be modded too, but I'll try to sell the one I have instead of chopping it.
My Nikkor mod: At the bottom of the aperture ring is the Aperture Ridge. On some lenses, it extends 360 degrees around the aperture ring. That can be tedious to grind off, and I haven't done so yet. On other lenses, the ridge is just an arc on one side of the ring, and a nub on the other. Those are easy to Dremel away, using a metal-cutting blade. Non-Nikkors with NI mounts may have a small set screw on the side of the bayonet, that prevents it engaging the Pentax mount windgs. I just removed the screw, and the lens base hasn't fallen out yet.
